Home > Technical (L322) > Several fault codes... Start with battery?
tezza
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Orkney Grey
Cleared all fault codes this morning. Re checked and this list was registered.
As far as I can tell all of these things are working fine, although I have recently started to see the parking brake icon flashing on the dash, not always and usually if it's sat with just ignition on for a while.
Looking at the voltage reading of 12.0v I'd imagine that battery needs changing so I guess start here anyway.
My car doesn't have start/stop and from what I've seen that means I don't need an AMR type battery, it currently has a varta g3 blue so not an AMR. Is there any advantage to having the AMR type even if it's not strictly required?
Post #603402 10th Aug 2021 7:02pm
PeteT80
Not sure what a AMR battery is, you need to get a AGM type fitted such a a Varta G14.
Post #603403 10th Aug 2021 7:20pm
tezza
I think it's clear that was a typo and AGM is indeed what I meant to type, my question was do I actually need that type (most likely not) and is there any benefit to an AGM outside of a start/stop enabled car
Post #603405 10th Aug 2021 7:24pm
rjff
As Pete says, you need an AGM battery for your FF.
On early 2011MY I understand there was a recall to fit that type and later such as yours should have been supplied with an AGM. Someone may have been penny pinching.
If you think you don't need an AGM have a search on here for the topic, it may well inform you about those codes too Thumbs Up Cheers
Richard
Gap IIDBT
Post #603421 10th Aug 2021 9:18pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Re: Several fault codes... Start with battery?
First two are bizarre. I have them on mine but a new battery and alternator didn’t stop them returning. If your battery is only showing 12V it should probably be changed regardless.
The Parking Brake issue could be a battery but is most likely a wiring issue. It was on mine.
The final one is the EGR temperature sensor that is nowhere near the EGR valve (it’s on the exhaust manifold as is a pain to get to).
Post #603423 10th Aug 2021 10:30pm
tezza
Changed battery today for a Varta AGM upon the suggestions from Pete and rjff. Made no difference to the faults, they're all back after clearing and going for a drive.
Now I've got window weirdness added to the mix... I can no longer one-touch open or close the windows from the buttons inside the car.
Holding down the unlock button on the remote opens the windows as expected, holding down the lock button does not close the windows any more!?
Post #603633 12th Aug 2021 6:10pm
PeteT80
You can recalibrate the windows with the IID in the service menu under body control
Post #603636 12th Aug 2021 6:52pm
Dean_C
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Think you need to set the windows, after battery change.
Can’t help with the errors codes but Someone with more knowledge may be along soon.
The windows though I believe you lower the windows & then raise them by holding the buttons & keep buttons held for a further 5 seconds after they stop at the top.
Also you may need to calibrate the steering, again after battery change, this is just lock to lock a few times.
Post #603639 12th Aug 2021 7:03pm
tezza
Legends thank you Bow down Thumbs Up
Battery is still showing 12.0v and estimated 78% charged. I did take it out for a 30 minute drive after changing the battery so was surprised to see it so low.
I did do the battery change in iid after putting the new one in. Not sure if I need to change the battery type under car config but there's nothing there that seems like it relates directly to the battery I've put in. I'll have a read through the iid docs now and see if I'm missing something
Post #603643 12th Aug 2021 7:26pm
rjff
Tezza
You may have checked, but what voltage is the alternator charging at. It's a known fail on 11MY on. It should be up around 14.4-14.6 volts. When/if it fails it may also b****r the battery (ask me how I know).
Your first two codes have come up on mine previously without any further problems and IIRC there's a recent(ish) post saying B prefix codes are not to worrying.
HTH Cheers
Richard
Gap IIDBT
Post #603680 13th Aug 2021 7:53am
Mike Edwards
I got rid of the more awkward codes with a new battery but soon realised it was down from 14.4v to 12v quite quickly. Fitted a new alternator and back up to 14.4v again.
Post #603692 13th Aug 2021 10:19am
tezza
With the engine stopped, on the meter the new battery shows 12.2v, at tickover 12.5v
Now I'm sure I checked this before and was seeing 14.something at tickover with the old lead acid battery on so idk if that lower voltage is the bcm limiting the charge after doing the battery replacement routine in iid or if I have an alternator issue.
I'm about to take it for a run down the motorway so will check the figures after that and see where it's at.
Post #603697 13th Aug 2021 11:16am
PeteT80
The later 4.4TDV8 fitted with a AGM battery charges differently and the alternator works in a different way than the older ones fitted with a lead acid battery there’s a few threads about it on here somewhere.
Post #603698 13th Aug 2021 11:26am
tezza
Been out for a decent run, watching live values in iid varied from 13.0 to anywhere up to 14v, now with the engine off reading 12.7 so I guess everything is looking ok. Just keep an eye on it now for a few days. Cheers all Thumbs Up
Post #603709 13th Aug 2021 2:25pm
rjff
You can get live voltage whilst running without using the iid if you wish.
Press the Home hard key to the left of the TFT screen
Press on the centre of the white bar at the top of the screen for 5 seconds
Press the navigation hard key for 5 seconds, or until the numeric keypad appears
Press 753 followed by Enter
Select Vehicle Signals
Compare the reading with your voltmeter/iid so you know what the differences are, if any.
Have a look around the other screens to see what's about.
HTH Cheers
Richard
Gap IIDBT
Post #603713 13th Aug 2021 3:46pm
