Home > Technical (L322) > Several fault codes... Start with battery? |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 211 |
Not sure what a AMR battery is, you need to get a AGM type fitted such a a Varta G14. |
10th Aug 2021 7:20pm |
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 |
I think it's clear that was a typo and AGM is indeed what I meant to type, my question was do I actually need that type (most likely not) and is there any benefit to an AGM outside of a start/stop enabled car |
10th Aug 2021 7:24pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
As Pete says, you need an AGM battery for your FF.
10th Aug 2021 9:18pm |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 |
First two are bizarre. I have them on mine but a new battery and alternator didn’t stop them returning. If your battery is only showing 12V it should probably be changed regardless. The Parking Brake issue could be a battery but is most likely a wiring issue. It was on mine. The final one is the EGR temperature sensor that is nowhere near the EGR valve (it’s on the exhaust manifold as is a pain to get to). |
10th Aug 2021 10:30pm |
Changed battery today for a Varta AGM upon the suggestions from Pete and rjff. Made no difference to the faults, they're all back after clearing and going for a drive.
12th Aug 2021 6:10pm |
You can recalibrate the windows with the IID in the service menu under body control |
12th Aug 2021 6:52pm |
Dean_C Member Since: 30 Apr 2021 Location: Lancashire Posts: 41 |
Think you need to set the windows, after battery change.
12th Aug 2021 7:03pm |
Legends thank you
12th Aug 2021 7:26pm |
Tezza
13th Aug 2021 7:53am |
I got rid of the more awkward codes with a new battery but soon realised it was down from 14.4v to 12v quite quickly. Fitted a new alternator and back up to 14.4v again. |
13th Aug 2021 10:19am |
With the engine stopped, on the meter the new battery shows 12.2v, at tickover 12.5v
13th Aug 2021 11:16am |
The later 4.4TDV8 fitted with a AGM battery charges differently and the alternator works in a different way than the older ones fitted with a lead acid battery there’s a few threads about it on here somewhere. |
13th Aug 2021 11:26am |
Been out for a decent run, watching live values in iid varied from 13.0 to anywhere up to 14v, now with the engine off reading 12.7 so I guess everything is looking ok. Just keep an eye on it now for a few days. Cheers all |
13th Aug 2021 2:25pm |
You can get live voltage whilst running without using the iid if you wish.
13th Aug 2021 3:46pm |
