Home > Maintenance & Mods (L322) > Terra Clean
Baltic Blue
Terra Clean
78,500 miles on the clock, so guess what, first signs of oil leaking from cooler gaskets.
I have just had both gaskets replaced , plus the O rings on the turbo feed pipe by Mills 4x4, my local independent garage.
The owner/ mechanic was rather taken aback by the amount of “crud” he removed from the plenum chamber and throttle body.
He asked me if I have considered having the car Terra Cleaned.
He can’t offer the service, so wasn’t after extra work, but thought it might be a good time to get it done whilst I know it won’t be flushing too much crud through the system because he has cleaned out as much as he could.
Any experience/ thoughts would be appreciated for me to consider.
I have found a fairly local agent , but thought I would ask on here for any experience/ thoughts.
Post #603619 12th Aug 2021 5:23pm
kevinp
Hi Mike. I had it done on my Santa fe that was really clogged up in the inlet manifold. I'm sure the cleaner is connected direct to the fuel lines so doesn't touch the inlet manifold or throttle body. It was still the same after. It obviously goes through the injectors though. Can't comment on whether it did anything because I had it remapped at the same time.
Post #603623 12th Aug 2021 5:47pm
Dolphinboy
Some night-time reading for you Mike,
https://www.fullfatrr.com/forum/topic34133.html?highlight=terra
https://www.fullfatrr.com/forum/topic12517.html?highlight=terra
https://www.fullfatrr.com/forum/topic31584.html?highlight=terra
http://www.fullfatrr.com/forum/topic11748.html
https://www.fullfatrr.com/forum/topic12654.html?highlight=terra
Post #603624 12th Aug 2021 5:47pm
Baltic Blue
Thanks for the replies.
I have just been out for a good run , then parked in my garage with its newly painted floor, so I will know tomorrow if the leak is fixed.
I must add that the car is running perfectly, so my gut thought is to leave well alone, but I will read all the links then decide.
I have got two fairly long trips , one on Sunday , and again on Monday.
If it seems OK then I will wait before doing anything.
Post #603644 12th Aug 2021 7:27pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Always been under the impression that terraclean is more for the fuel lines and injectors. I think if you want too clean all the carbon build up your better off whipping the items off and cleaning them yourself
Post #603659 12th Aug 2021 8:59pm
mjdronfield
I’m mostly an advocate of don’t fix what’s not broke.
If it’s running well, you will be kicking yourself if there are issues after doing it.
I second your plan....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #603661 12th Aug 2021 9:09pm
