Home > Technical (L322) > Oil around turbo hose.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Is this much oil normal around here?
 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #587001 11th Mar 2021 8:19am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
you always get a mist of oil in the hoses i guess over the years it builds up.
I would remove clean inspect and put it back then check it again in a few weeks 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #587002 11th Mar 2021 8:25am
umitbat
I also think like you but the other side is so dry.
The hose is so small does it have any difficulty to remove? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #587004 11th Mar 2021 9:00am
Jayk69
i am just looking at your picture again there is a little pipe that looks like it should be connected 2012 Vogue 4.4 TDV8 - Current
Post #587009 11th Mar 2021 10:09am
Jayk69
Post #587010 11th Mar 2021 10:11am
umitbat
Yes it was loose I took out to take pictures.
Is it the hose from air filter?
Thanks mate!! 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #587061 11th Mar 2021 3:57pm
Jayk69
it looks like part of the vacuum line to me, apologies as i do not have a 3.6 so do not know for sure.
best you can do is trace it see where it goes 2012 Vogue 4.4 TDV8 - Current
Post #587155 12th Mar 2021 9:17am
Sansonneche
France 2009 Range Rover HSE TDV8 Santorini Black
I've got the same thing, and thinking that if oil can get out, so can air. Did you manage to get it changed? Any tips as if looks like it could be a real pig to do? Mark
3.6TDV8 HST, Santorini Black
Yam 350 Bruin quad, mud coloured
Post #603064 6th Aug 2021 10:34pm
umitbat
No just cleaned it everyone says it's normal. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #603085 7th Aug 2021 9:11am
