Home > Technical (L405) > Entering extended mode
scotsjon
United Kingdom 2016 Range Rover Autobiography SDV8 Farallon Black
Chaps
A couple of times recently (McDonald’s drive thru and parking on my drive) the vehicle has extended mode….. it thinks I’m stuck??
Whilst on my driveway I pressed access mode and the thing was going up and down like crazy. I drive round the block and parked again to try and replicate it but had no success.
Is something on the way out? a sensor perhaps? Or should I chalk this down to character.
If anyone else has experienced this then please share
Cheers
Jon
Post #602990 6th Aug 2021 11:48am
scotsjon
Edit: has entered extended mode
Post #602991 6th Aug 2021 11:49am
mjdronfield
When it tried to lower, it sensed it wasn’t lowering fast enough, or it didn’t get to the desired lowered height. It then decided that this was probably due to an obstruction underneath, so went to extended mode so you stood the best chance of driving over the obstruction... that wasn’t there....
I’d check the exhaust filter on the air compressor in the boot. Sometimes get blocked and it can’t get rid of the air (to lower) fast enough....
I drilled a hole in mine when it went to extended mode, and then wouldn’t come down at all....
Might be something else, but this would be an easy fix....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #602992 6th Aug 2021 12:06pm
bishbosh10
This is usually caused by the exhaust filter on the compressor blocking up (they all do it eventually). This slows the release of air to such an extent that the car thinks you're grounded (as the car isn't lowering fast enough) and sends itself into extended mode to try and clear the obstacle.
The simple fix is to drill a small hole through the filter. A quick search on the forum will turn up a few threads on this. Thumbs Up Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #602999 6th Aug 2021 12:41pm
knwatkins
Whilst the compressor is exhaust valve is the most likely suspect for you, I had this problem on my old Sport and it ended up being the front offside shock that was knackered and unable to compress when going into access mode. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #603023 6th Aug 2021 4:08pm
scotsjon
Thanks for the input guys, TBF it hasn’t done it since, I will let it develop further before I start taking action
Cheers
J
Post #603159 8th Aug 2021 1:18am
mjdronfield
Sounds like a plan. Don’t poke the tiger 🤣🤣
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #603190 8th Aug 2021 12:26pm
