Home > Technical (L322) > Suspension Fault Max Speed 30mph |
Chapeau! Velo Member Since: 22 Jul 2019 Location: Down South Posts: 115 |
A really helpful read as my 08 L322 suspension is behaving in exactly the same way. Great pointer for me to discuss with the indi tomorrow (who to be fair will probably be all over this!) |
4th Aug 2021 10:12pm |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 253 |
Unnecessary quote removed
5th Aug 2021 11:35am |
West 4x4 in Bishops Waltham |
5th Aug 2021 11:57am |
I’ll be interested to hear the diagnosis - keep us posted. 2011MY 4.4TDV8 Autobiography Baltic Blue
5th Aug 2021 12:02pm |
Any update? 2011MY 4.4TDV8 Autobiography Baltic Blue
8th Sep 2021 12:09pm |
Of course! A simple fix; a new front drivers side suspension strut owing to a leak / split in the old one. Essentially the compressor was working overtime to keep the system full of air owing to the leak and shutting down when it got a bit hot. All good now. |
8th Sep 2021 12:13pm |
Thanks for the update. Was your front corner sinking overnight? Still trying to get to the bottom of my issue - intermittent faults are the worst! 2011MY 4.4TDV8 Autobiography Baltic Blue
8th Sep 2021 12:19pm |
The whole car would sink when stationary and engine off, not just that corner, presumably owing to all the air in the system escaping via the split. |
8th Sep 2021 12:22pm |
Fred Member Since: 04 Nov 2021 Location: Fermanagh Posts: 1 |
I have the same suspension problem, can you send me detail of your repair guy
4th Nov 2021 10:42pm |
Eventually got to the root cause of my 'cross-articulation algorithm' fault - replacing the n/s/r height sensor has done the trick. Odd that it did not come up with a specific height sensor fault code though. 2011MY 4.4TDV8 Autobiography Baltic Blue
13th Jan 2022 7:04pm |
