![]() | Home > Technical (L405) > SDV8 EGR Valves. |
Landphil Member Since: 03 Oct 2016 Location: U.K. Posts: 119 ![]() ![]() |
If it’s an SDV8 it’s “relatively” modern and as such you can’t blank the EGRs as it would be illegal and would leave you with an EML, which would lead to an MOT failure.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 777 ![]() ![]() ![]() |
I believe the problem with blanking EGR valves on engines with DPFs, is that the EGR valves are used to regulate the very high temperatures that are used to perform the regeneration of the DPF.
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
104,000 miles on my 2017 SDV8 and not a single issue with the EGR valves to date 👍
GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 238 ![]() ![]() ![]() |
Many thanks, I’m in serious learning mode. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2669 ![]() ![]() |
The engines have a single EGR valve located in the V underneath the oil filter and cooler housing.
Ah, that makes sense Graeme |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
So the reason someone will delete egr is to increase performance, increase mileage, try and rid of diesel engine issue.
My question was posed due to my experience with the 2,7 TDV6. They are troublesome in this engine, and are best blanked off. I was just asking if the SDV8 had the same problem. It obviously does not, so thanks for the explanations. |
The 4.4's inlet tract gets as clogged as the 2.7's from exhaust gases mixing with oil vapour from the turbo(s). The only way to avoid the build-up would be to drive so that the EGR valve is never opened such as never allowing the engine to idle and never allow the engine to run on light throttle which are totally impractical options.
GraemeS like Landphil mention, it is illegal to delete egr or dpf in the UK. So it is not worth the research. |
I'm not in the UK and my L322 doesn't have a DPF. |
Plus, anyone should feel free to research whatever they want. What's deemed 'not worth the research' to one person, may be completely relevant and of interest to another.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4336 ![]() ![]() ![]() |
Talk to the "Derv Doctor" or "Durham Remaps" for any EGR/DPF mods on the 4.4 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Oh, and for gearboxes/diff oils changes then get Ian Bodsworth down from Telford (mobile) and he'll do it all on your drive. He knows his stuff and will be way cheaper than a main dealer and do a better job.
