![]() | Home > Maintenance & Mods (L322) > How to Remove RSE Centre Console AV Panel? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 90 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic58324.html
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
I will try tonight and post photos. 2015 Range Rover Autobiography 4.4 SDV8 |
FYI - it was an easy job as per the documents. The hardest part is removing the screw that holds the top armrest in place. Its long and needs to have retaining clips removed on both sides.... You can break these and thats not good.
So, I had a fiddle tonight.
Unfortunately, after a bit of fiddling, the connections inside the 3.5mm jack are now loose and I need to buy a new module - doh! So, if you don't have RSE, you're in luck. You can unscrew the unit and there's a little ledge to put it on behind the centre of the arm rest. Then it's just a case of drilling a hole and feeding a 3.5mm cable through. For RSE, an auto electrician may be able to trace the ribbons and splice in but I couldn't fathom it - trying the L and R feeds from the Jack only resulted in mono high range sounds through the car stereo. I think therefore, the solution is to purchase a 3.5mm cable with a 90 degree end. This will allow the dust cover over the AUX inputs to be closed and, feed the cable under and through the centre console, drilling a small hole for it in the arm rest. This seems the neatest install option with no cable on show. 2015 Range Rover Autobiography 4.4 SDV8 |
