![]() | Home > For Sale & Wanted > [Wanted] WANTED - L322 Westfalia Tow Bar |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
I think you've been given some duff info sir...
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
There's Westfalia plated fitments on my car with what looks like + shaped holes for a cross bar to bolt into? 2015 Range Rover Autobiography 4.4 SDV8 |
Yes Westfalia made the parts on your car for all production L322's sir...
I'm just asking the question why they're there and what that plus shaped hole is, over just an exhaust bracket? 2015 Range Rover Autobiography 4.4 SDV8 |
I think, from memory, the shaped hole is to but a bolt through? No?
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2051 ![]() ![]() |
As Craig says the unit is one complete piece, requiring the removal of the 2 current brackets
So then, is there anyone on this forum who sells either detachable or adjustable for a 2011 L322?
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 ![]() ![]() ![]() |
Hi, I have one of the Tow Trust tow bars. It has the same ratings 150KG nose weight and 3500KG trailer.
Point to note is that the OEM Westfalia armature is no longer made, so if you want that one you will need to buy a 2nd hand one. |
