Home > For Sale & Wanted > [Wanted] WANTED - L322 Westfalia Tow Bar |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
I think you've been given some duff info sir...
27th Jul 2021 11:54pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1478 |
There's Westfalia plated fitments on my car with what looks like + shaped holes for a cross bar to bolt into? 2015 Range Rover Autobiography 4.4 SDV8 |
28th Jul 2021 12:02am |
Yes Westfalia made the parts on your car for all production L322's sir...
28th Jul 2021 12:21am |
I'm just asking the question why they're there and what that plus shaped hole is, over just an exhaust bracket? 2015 Range Rover Autobiography 4.4 SDV8 |
28th Jul 2021 12:27am |
I think, from memory, the shaped hole is to but a bolt through? No?
28th Jul 2021 12:33am |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2033 |
As Craig says the unit is one complete piece, requiring the removal of the 2 current brackets
28th Jul 2021 6:18am |
So then, is there anyone on this forum who sells either detachable or adjustable for a 2011 L322?
28th Jul 2021 8:16am |
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 |
Hi, I have one of the Tow Trust tow bars. It has the same ratings 150KG nose weight and 3500KG trailer.
28th Jul 2021 9:00am |
Point to note is that the OEM Westfalia armature is no longer made, so if you want that one you will need to buy a 2nd hand one. |
28th Jul 2021 4:31pm |
