Home > Technical (L405) > 2013 L405 SDV8 Bouncy ride, harsher over bumps |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
I had the same on my old Sport. Replaced all four strut assemblies and it solved the problem. Kev
26th Jul 2021 4:52pm |
James Brown RR Member Since: 26 Jul 2021 Location: Cheltenham Posts: 19 |
Thanks Kev, out of interest what was the mileage on your sport when you changed the struts and why did you change all 4 |
26th Jul 2021 9:07pm |
It was on about 95k at the time.
26th Jul 2021 9:18pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Im not a million miles away from you and own my own 2013 and have been through every issue you have with yours sir... |
26th Jul 2021 10:57pm |
Bigfella70 Member Since: 22 Jan 2016 Location: Yorkshire Posts: 104 |
James, I’ve been looking for a 405 to replace my current 322 and test driven four cars, all 4.4 SDV8 versions from model year 2014, 2015, 2016 and 2018 with a variety of mileages. All had what I’d describe as a slightly choppy and noticeably bouncy sensation to the ride. This is especially in comparison to my 322 which is very stable in comparison.
27th Jul 2021 5:37am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
My money is on the shocks being worn-out but as a test switch off DSC then see if the ride is improved. With DSC off the shocks are set firmer but if worn-out then there won't be much of an improvement. |
27th Jul 2021 8:05am |
Good point - I have had two newer 17/67 reg L405's - one an SDV6 and the other SDV8 but not for six months - I am quite fussy but there is a problem over bumps with the bounce and slightly harsh ride I think. On a flat road the ride is excellent and smooth - I will have a drive of a friends 17 reg SDV8 just to make sure I'm not imagining the problem though. KR, James |
27th Jul 2021 9:11am |
Thanks Graeme I'll give it a try |
27th Jul 2021 9:13am |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 766 |
That's exactly my feeling. Mine was bouncy and choppy since new! The same roads I used with the L322 are way less forgiving with the L405... |
27th Jul 2021 1:29pm |
Just reporting back - I had the two front struts replaced and the car is totally transformed and now rides like a full fat RR SDV8 should. In fact the ride is now comparable to my previous ff RR's which had 19k and 25k on the clock rather than the 132,000 that this one has covered.
11th Sep 2021 11:08am |
Great news Kev
11th Sep 2021 9:11pm |
