Home > Technical (L322) > Am I a dipstick? What is this thing?
tezza
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Orkney Grey
I twisted and pulled this (the thing with the turn symbol, not the oil filler 😁) on my 4.4tdv8 expecting it to be a dipstick but it wasn't. Anyone know what it is?
Went back fine but now thinking I shouldn't have touched it.
Post #601804 25th Jul 2021 9:15pm
mjdronfield
That’s the hole where you use a vacuum pump to drain/remove the oil from above.
The 4.4TDV8 doesn’t have a dipstick....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #601805 25th Jul 2021 9:22pm
tezza
Just the one in the driver's seat then 🤣
Thanks, do you not just drain the oil from sump plug then? I feel old, cars used to be simple 🙂
Post #601808 25th Jul 2021 9:26pm
mjdronfield
You can... but it’s much faster and easier from above. You need a suction pump. Have a search on the forum.
The manual will cover how to check the oil level using the instrument cluster menu, if you’ve not seen that bit....
https://www.fullfatrr.com/forum/topic41966...ction+pump
How to here....
https://www.fullfatrr.com/forum/topic52688...ction+pump
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #601811 25th Jul 2021 9:32pm
tezza
Thanks for the info, I did check it via the service menu but thought I'd verify that with the analogue method 🙂
Actually seems fairly simple to do an oil change, I like that, especially if you cover decent mileage although don't expect I'll cover much more than 5k a year so annual change should be all I need.
Thanks again, loving the amount of knowledge kicking around here Thumbs Up
Post #601814 25th Jul 2021 9:44pm
Dipstick..... Ner Ner Rolling with laughter Thumbs Up
Post #601820 25th Jul 2021 11:53pm
