Home > Technical (L322) > Am I a dipstick? What is this thing? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
That’s the hole where you use a vacuum pump to drain/remove the oil from above.
25th Jul 2021 9:22pm |
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 |
Just the one in the driver's seat then 🤣
25th Jul 2021 9:26pm |
You can... but it’s much faster and easier from above. You need a suction pump. Have a search on the forum.
25th Jul 2021 9:32pm |
Thanks for the info, I did check it via the service menu but thought I'd verify that with the analogue method 🙂
25th Jul 2021 9:44pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Dipstick..... |
25th Jul 2021 11:53pm |
