Home > Technical (L322) > Droning / buzzing coming from air vents
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Is intermittent and can’t recreate all the time
But is speed dependant. Slowing down to below 60 removes the droning.
Anyone else experiencing this?
Post #601675 24th Jul 2021 7:14am
DrRob
Try closing then opening it at speed and see if that resolves it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #601677 24th Jul 2021 7:16am
nick4275
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I had something like this, it turned out to be the external trim below the windscreen, the one surrounding the wipers.
The odd looking fasteners must hold this trim really firmly or it will drone and then echo through the internal air vents.
It is a speed dependant issue as the trim only vibrates when the air passing over it is at a certain speed.
You can get the clips on eBay.
Hope that helps.
Post #601702 24th Jul 2021 1:29pm
Rambles
Thanks Nick
Do you have some pictures of the trim you mean? Is it the clips that hold the wiper blades to the arms ?
Post #601874 26th Jul 2021 4:46pm
nick4275
Sure,
Photo attached shows trim below windscreen, it runs along the entire bottom of the windscreen.
The clip holding it is the grey circle you can see in the trim.
Have a look at Nut Job's YouTube channel -
This shows the whole problem and his solution in great detail.
Part code for clips is CYC000010. Rimmer Bros. sell them.
Good luck !
Post #601911 26th Jul 2021 9:19pm
Rambles
That’s the noise !
Thank you 🙏 for sharing
Post #601935 27th Jul 2021 6:17am
