Home > Technical (L322) > ZF 6HP28 tranny service |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Deleted |
26th Jul 2021 12:35pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8222 |
"If it ain't broke don't fix it" should be etched on the side of every fatty box...
26th Jul 2021 1:36pm |
Deleted |
26th Jul 2021 2:54pm |
andyducati Member Since: 01 Sep 2017 Location: Eltham, Victoria Posts: 25 |
Thanks all. All comments are a good point. I wasn't sure about the solenoids, just read on another post about changing the solenoids.
27th Jul 2021 3:38am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 737 |
Which fluid to use?
27th Jul 2021 7:32am |
Deleted |
27th Jul 2021 7:48am |
I'm not saying their oil is or isn't an exact copy of the ZF approved oil but no one, including the original oil maker, state what friction modifiers and other additives are in the oil, the base stock maybe the same but this doesn't mean the whole package is the same... It "might" be exactly the same... there again, loads of people have found out the hard way that "some times" it isn't.... If you are happy using another oil on that basis then great... Also IMHO with the miles on your box I would just do a drop what's in the sump, change the sump and refill with new, then drop and change it again in a few thousand miles... why...? Swapping out all the oil in one go will shock the box as the pressures within will rise sharply... do a few drop and fills and you gently raise the pressures and the box has time to adapt... I might be talking but that way has always worked for me.... Again, it's all down to what you are happy to try with your box.. Good Luck... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
27th Jul 2021 8:52am |
Deleted |
27th Jul 2021 9:48am |
Fact - LRPhil knows these boxes inside out, quite literally, he knows more about these than me. Read a few of his posts on here.
27th Jul 2021 9:55am |
Deleted |
27th Jul 2021 11:00am |
This is the information sheet for the Penrite BMV oil. https://www.penriteoil.com.au/assets/pis_p...20Syn).pdf
27th Jul 2021 11:45am |
Deleted |
27th Jul 2021 12:44pm |
