Home > Maintenance & Mods (L405) > Preventative maintenance
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
Hi
Having now had my 2013 RR VSE 4.4 SDV8 for nearly 12 months, is there any preventative maintenance that you would recommend? I have already had the fluid in the gearbox, transfer box and both differentials replaced as well as a full service. Next on the list is to replace the dynamic suspension reservoir and fluid as I don't know if this was changed when it was supposed to be.
Car is one owner and has a full service history and has done around 86000 miles.
TIA
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #601566 23rd Jul 2021 9:15am
Full Service History from a dealer could just be oil and filter changes if the owner specifies the basic service every time... JLR allow this...!!!
All fluids have a shelf life, even if they don't wear out....
You have
Engine
gearbox
transfer box
2xaxles
brake fluid
suspension fluid
power steering fluid (I presume the 405 does)
coolant
Personally I always change the lot when I get a new vehicle, then you know it's done and you have a base line...
If you plan on keeping it for a while then get this sprayed underneath...
https://www.rust.co.uk/product/cat/corrola...roofing-43
or any other rust preventative you fancy...
Don't forget wipers as worn ones can damage a screen quickly....
Then look at all water and intake hose replacement if they are showing any sign of deterioration.
That lots a good start, I'm sure more idea will follow....... Thumbs Up Pete
Post #601573 23rd Jul 2021 10:18am
Baltic Blue
I’ll just add
2 x Air filters
1 x cabin air filter
1 x fuel filter.
Post #601574 23rd Jul 2021 10:35am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
At that mileage i would look at Tensioners, Belts and Pullies too these often get overlooked. I did mine at 116k and glad i did as parts of the main belt were missing Shocked so was a ticking time bomb.
As the job is so much effort i changed out the water pump too, nothing wrong with the original just that new belts can finish off a old water pump. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #601585 23rd Jul 2021 12:55pm
Landphil
The Power steering is electric not hydraulic, so one less to do.
Post #601587 23rd Jul 2021 1:08pm
