Home > Maintenance & Mods (L322) > Air con condenser removal |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Did this job today. Made easier by this thread 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
28th Aug 2015 8:58pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
31st Aug 2015 7:23am |
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 |
Sorry for resurrecting an old thread but am doing this job at the weekend, I've bought the condenser from coolparts uk however they don't supply the 2 "O" rings, so I ordered them from land rover but they dont seem to be the correct size when tried on the new condenser, so for those of you who have done the job did you use the ones from the old condenser or could you tell me where you bought the new ones. Thanks |
8th Apr 2016 9:49am |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
I fitted one last weekend also purchased from coolparts. I also purchased the o ring kit from them, it is a generic kit full of different sized o rings but not a pair so had to use two that just fitted. Just need to fix an engine fault before I can drive it to get the system recharged. |
8th Apr 2016 9:22pm |
Well thanks to the write up I managed to change my condenser at the weekend, took about 2hrs in total but that included aralditeing the passenger side headlight brackets back on ( very brittle ) . and also worth mentioning that the self tapper under where the pipes connect is a 25TX bit, took me a while to figure out after try different screwdrivers as you can't really see the head. |
11th Apr 2016 7:05am |
Had the system tested,re-gassed and the anti bacterial treatment done yesterday for 45, now ice cold 3.4 degrees at the vent |
25th Apr 2016 12:00pm |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 |
Gonna tackle this job hopefully tmw will have the thread up on my phone for reference.
13th May 2019 1:48pm |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
I swapped my condenser today on my 4.2SC after it failed a leak test. The guide was a real life saver. Thank you.
30th Jun 2019 8:02pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
I replaced the condenser and one of the alu aircon pipes in the engine bay this weekend. I didn't have to worry about capturing the old gas as it had all escaped previously.
17th May 2021 8:37am |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
Thanks to this original post, replaced mine today 👍
22nd Jul 2021 7:01pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
great post i have to replace my compressor nd this looks like a front end strip down same as when i did my belts and tensinors so may as well change the condenser at the same time as it will be out. 2012 Vogue 4.4 TDV8 - Current
23rd Jul 2021 7:18am |
Bronjen Member Since: 13 May 2018 Location: DE2 Posts: 44 |
I've just changed my condenser, wish i had looked in the forum first, as I took a different approach.
23rd Jul 2021 8:39am |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 146 |
I have just had my condenser replaced by John Delaney motors, Stockport.
24th Jun 2022 10:32am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1347 |
Too late to ask if the price is right, if they've already done the work. |
24th Jun 2022 11:04am |
