Home > Maintenance & Mods (L322) > Air con condenser removal
Page 2 of 4 <1234>
Arrived today, did the swap over this evening. No real dramas. Existing condenser was also a replacement, not LR, appears to have "gone" in the same place as the OP. Also that corner seems to be a leaf and bug magnet, so took some time to clean out this and the opposite corner, scraping with a wire coat hanger and vacuuming out. I removed the electric fan cover for better access.
Oh, my new condenser had the drier fitted. You can tell by the fact that the left hand bottom corner is sealed with a plastic hex plug, and if you tip the condenser up and down you feel a gentle thud. My new condenser also had threaded studs fitted where the two allen key bolts go. I removed these using the time honoured two nut method. Support the rectangular block with hands or adjustable spanner if applying any pressure to prevent damage.
I gave the bottom end and all the brazed joints a good greasing with general purpose grease before refitting. New one slid back in nicely and all put back together.
Off for a regassing, hopefully and cool interior. .
Post #273829 31st Jul 2014 8:40pm
Welshdragon
Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Easy peazy isn't it Mr. Green If it dont work.......burn it!
Post #273833 31st Jul 2014 8:46pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Well you set me off condenser ordered to day and will be here on the 7th so swap it over soon as i get it and hope to be cool Cool Cool Cool for the weekend.
Post #274419 5th Aug 2014 1:57pm
steve9bug
Did the swap today at my garage, got the car bonnet up at 9.00am and had this post up ready just finished and put all the tools away great post and a fantastic help why did i wait a year to do the job Cool
41 MINUTES Just need to get her gassed up Saturday and cool air for the weekend all being well.
Got the Condenser unit over night of Flebay guys £84.00 all in if you are looking for one 2 year cover on it.
THANKS AGAIN GREAT SITE PLEASED I AM A MEMBER
Post #274777 7th Aug 2014 8:47am
Welshdragon
Thumbs Up , done in good time too well done Thumbs Up If it dont work.......burn it!
Post #274808 7th Aug 2014 11:48am
..and no screws/bolts left over? ... - .- -.
Post #274812 7th Aug 2014 12:14pm
steve9bug
no bits left LOL and had her gassed up and cold as a fridge Razz Razz
Post #274823 7th Aug 2014 3:36pm
another place to keep the milk then.. Laughing ... - .- -.
Post #274834 7th Aug 2014 4:52pm
Gassed up today. Brrrrrrrr!!! .
Post #275013 8th Aug 2014 8:11pm
Welshdragon
Got frost bite Tim Rolling with laughter Rolling with laughter If it dont work.......burn it!
Post #275028 8th Aug 2014 9:16pm
johnboyairey
i did mine a while back as I was changing the water pump, and took the water rad out, therefore not removing the slam panel. grill was off from memory. no dramas, but those union bolts, sure are tight. give em a soaking, and another just before you turn em. I think I had to get some moles on one...I had to change out my pump too at same time, (about £250 online) so water rad out as necessary. -only three bolts. jobs still a good-un.
its a new luxury -picking air-con bogeys!
Post #275036 8th Aug 2014 10:16pm
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
I have been having air con problems. Bought a UV torch and discover bright green dye on the bottom corner of the condenser. Going to replace thanks to this handy DIY. Did you use any special air con oil on the o rings? 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #281266 15th Sep 2014 7:35pm
Welshdragon
Nope just a good lick Laughing ....or you could use some wd40, just mind the pipe housing goes on straight and pull up squarely Thumbs Up If it dont work.......burn it!
Post #281269 15th Sep 2014 7:40pm
666tur
Thanks Welshdragon. What am I pulling up? The aluminium air con pipes that connect to the condenser?
Did you need to do no nothing with the drier? Going to give it ago, deliberating over ordering one from autoaircon for £80 or a Nissens one from eBay for £132. Both 2 year warranty. Thanks again. 2012 4.4TDV8 VSE
Post #281278 15th Sep 2014 8:03pm
The drier should be included/built in to the condenser - other end to the connections - white plastic six sided plug. If you tilt the new/old unit you should hear a clunk. .
Post #281288 15th Sep 2014 9:02pm
Page 2 of 4 <1234>
