Home > Technical (L322) > Powering a phone on the dash
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
I’ve fitted a suction phone holder to the piano black air vent cover to the right of the steering wheel, I’m a tad ocd about cables and hate the fact there are no power points at the front of the dash, I want to hide as much of the cable as possible, has anyone done this and if so where have you got power from
And routed the cables to
Thanks in advance
Craig 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #599405 2nd Jul 2021 9:21am
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
I've got a charging cradle in the centre vents. Land Rover have left a handy gap between the piano black and the centre console to hide the wire in. It then goes by the seat and into the centre console where again there is a little gap for a wire so you can shut the lip properly. 2011 Vogue SE TDV8
Post #599420 2nd Jul 2021 11:32am
Furnitureman
In the end I took a feed from behind the light console and fed the cable inside the roof lining and down the A pillar very need and works a treat 2012 Range Rover Westminster 4.4 TDV8
Post #600952 17th Jul 2021 2:44pm
kooky_guy
Any more details on where you took the feed from?
I have the same issue, but don't want to take everything apart again to run a line from the fuse box. 2010 4.4 TDV8 Vogue SE
Post #601492 22nd Jul 2021 3:43pm
Furnitureman
As I don’t have the deplorable side steps I used the permanent live from there and fused it down, then ran the cable along the roof to the drivers A Pillar and down to the phone, I like to be able to charge the phone with engine off for short periods that’s why I did it this way 2012 Range Rover Westminster 4.4 TDV8
Post #601497 22nd Jul 2021 4:20pm
