![]() | Home > Technical (L322) > Powering a phone on the dash |
stevepen Member Since: 03 Feb 2017 Location: Cheshire Posts: 64 ![]() ![]() ![]() |
I've got a charging cradle in the centre vents. Land Rover have left a handy gap between the piano black and the centre console to hide the wire in. It then goes by the seat and into the centre console where again there is a little gap for a wire so you can shut the lip properly. 2011 Vogue SE TDV8 |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
In the end I took a feed from behind the light console and fed the cable inside the roof lining and down the A pillar very need and works a treat 2012 Range Rover Westminster 4.4 TDV8
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
Any more details on where you took the feed from?
As I don’t have the deplorable side steps I used the permanent live from there and fused it down, then ran the cable along the roof to the drivers A Pillar and down to the phone, I like to be able to charge the phone with engine off for short periods that’s why I did it this way 2012 Range Rover Westminster 4.4 TDV8
