Home > Technical (L322) > TDV8 4.4 - Engine Noise - Any Thoughts?
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
We are trying to identify the cause of this engine noise on a 2011 TDV8 4.4.
It's only done 92K miles but does seem to have been overfilled with oil by a previous owner (we bought it knowing there was some kind of engine noise). Before we started it we removed over five litres of oil using a vacuum pump and the dash still said it only needed one litre to top it up to the correct level.
It does sound a little out of sorts on the front left cylinder as you stand in front of the bonnet but we can't quite work out if the noise is from a problematic rocker, valve or something peculiar such as a broken am chain guide, etc.
All thoughts and suggestions welcome before I have to remove the head for a closer look.
https://youtu.be/M-sYeTO6818
https://youtu.be/WCkkh-OjNRU
https://youtu.be/z304hPZU_54
https://youtu.be/UdnxJ2_Cu7I
Post #601271 20th Jul 2021 3:44pm
kevinp
I think that area has the vacuum pump. Could be faulty? Non of your you tube videos work for me.
Post #601297 20th Jul 2021 5:56pm
Mike Edwards
What error do you get from YouTube?
Post #601299 20th Jul 2021 6:18pm
kevinp
Blank screen with 'private video'.
Post #601312 20th Jul 2021 7:44pm
Mike Edwards
Even now? Damn!
Post #601314 20th Jul 2021 7:50pm
Mr Tee
Works for me
Post #601315 20th Jul 2021 7:53pm
kevinp
Works for me now. That sounds painfully expensive!!
Post #601328 20th Jul 2021 9:50pm
4040
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
It doesn’t sound good to be honest. I think I would take the belts off along with anything else that turns externally including the vacuum pump. If it’s still there then it’s a case of stripping the engine. There is a warning in the manual to not drive it if it’s over filled. I guess there must be good reason for that. Hope you get it sorted.
I have also heard that the oil level sensor can go wrong giving a false display. Best to drain all oil and refill, you could have taken oil out for nothing if the sensor is Censored up ?
Post #601333 20th Jul 2021 11:00pm
Mike Edwards
Anyone heard this noise before?
Post #601842 26th Jul 2021 10:03am
