Home > In Car Electronics (L405) > Dash Cam
sorry i didnt explain myself properly...
what i meant was the novelty of looking at the recordings every 5 minutes ...
having a dashcam is an essential bit of kit and every car should have one... ... - .- -.
Post #601239 20th Jul 2021 11:12am
TJH1985
nbunney wrote:
ALL
Please be aware, after issues with getting a JLR dash cam to work in my 2014, I received this from Robin at Duckworths:
'this product is only meant for 2020 models onwards, fitting to earlier models is an unknown.'
So looks like I am £200 down the drain getting Range Rover World to fit it when he was upgrading my screen, but now have to pay to get it taken out to send back for a refund.
Expensive lesson Big Cry
I had been considering the JLR dash cam, what hasn't been working for you? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #601240 20th Jul 2021 11:13am
Chalky
Thumbs Up Thumbs Up All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #601241 20th Jul 2021 11:14am
nbunney
Rolling with laughter Rolling with laughter Rolling with laughter
Post #601243 20th Jul 2021 11:23am
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Recently did an install on my l322, at £160 the road Angel with hardwire kit is fab and has settings built in to shut the cameras off below a certain voltage very discrete and easy to fit
https://www.fullfatrr.com/forum/topic60177.html 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #601246 20th Jul 2021 11:39am
nbunney
TJH1985 wrote:
nbunney wrote:
ALL
Had it fitted and it connected to my phone, then, on numerous occasions tried to update the firmware.
Then only got red power and wifi indications, no green.
Then it went dead, nothing.
Checked the fuse and it had gone pop.
Changed it and still nothing.
Duckworths will now only refund on return, as they say it is only meant for 2020 models and newer.
Post #601262 20th Jul 2021 2:39pm
our Craig says he has fitted these successfully to his and other FF's and he knows his stuff....so i suspect that range rover world could have fitted yours incorrectly..
maybe you have a faulty unit? ... - .- -.
Post #601264 20th Jul 2021 2:45pm
nbunney
Stan
That's why I bought one.
And it is basically plug and play.
Remove harness to interior light. Plug it into dash cam loom. Plug other end of dashcam loom into the interior light socket. Mount front camera receiver. Run rear camera cable cable. Plug in cameras. Done. The camera wiring is all in 1 premade loom.
Not sure what the wiring differences will be between a 2014 and 2020, if any.
Post #601265 20th Jul 2021 3:23pm
I’ve fitted 12 of these to 405’s ranging from my 2013 to 2021 and have had ZERO issues! I think something else done to nbunneys car at the same time as the install will be the culprit!
Why not return the car to RRW and ask CD to investigate? I assume it drove away from wherever it was installed???
Post #601302 20th Jul 2021 6:58pm
nbunney
Yes it did Craig.
I will wait for my spare key to return from Adam and then see where we go.
Post #601374 21st Jul 2021 12:16pm
