![]() | Home > In Car Electronics (L405) > Dash Cam |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35513 ![]() ![]() |
sorry i didnt explain myself properly...
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 916 ![]() ![]() |
![]() ![]() 2021.5 Vogue SE D300 Carpathian Grey 2018 Vogue SE British Racing Green GONE |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2050 ![]() ![]() |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
Recently did an install on my l322, at £160 the road Angel with hardwire kit is fab and has settings built in to shut the cameras off below a certain voltage very discrete and easy to fit
Had it fitted and it connected to my phone, then, on numerous occasions tried to update the firmware. Then only got red power and wifi indications, no green. Then it went dead, nothing. Checked the fuse and it had gone pop. Changed it and still nothing. Duckworths will now only refund on return, as they say it is only meant for 2020 models and newer. |
our Craig says he has fitted these successfully to his and other FF's and he knows his stuff....so i suspect that range rover world could have fitted yours incorrectly..
Stan
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
I’ve fitted 12 of these to 405’s ranging from my 2013 to 2021 and have had ZERO issues! I think something else done to nbunneys car at the same time as the install will be the culprit! Why not return the car to RRW and ask CD to investigate? I assume it drove away from wherever it was installed??? |
Yes it did Craig.
