![]() | Home > General > What did you buy for your FFRR today? |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
bit of heat shrink over the terminals and jobs a good one new vehicle purchase 2007 supercharged 4.2 java black .sand leather vogue se trim previous cars . range rover classic 200 tdi discovery 1 200 tdi freelander 2 2008 hse discovery 1 300 tdi p38 4.0 ltr man r380 ex royal support vehicle on v5c discovery td5 man off roader |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Water in fuel sensor as mine seems to have gone the way of others on here and is flagging up the RP message every so often. Plan to fit this weekend so I can tick another box off the ever growing "To Do" list |
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 223 ![]() ![]() ![]() |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 675 ![]() ![]() ![]() |
Had a GPS tracker fitted from global trackers. £4 a month subscription, can't fault that at that price. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Nipped out to Euro car parts - Got Brembo front brake pads along with the usual new stainless clips and bolts with pre applied thread lock, now waiting for the damn rain to stop to fit them |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 594 ![]() ![]() ![]() |
Got and fitted the long missing front tow hook cover. As expected, it wasn't a straightforward job and probably that's the reason it was missing in the first place. 2 very discreet screws secured it in place nicely. Can still quick-remove (rip apart) with a firm pull in case of emergency |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
New rear light cluster as you can't change bulbs on the |
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 209 ![]() ![]() ![]() |
Canbus-compatible number plate light LEDs and LEDs to replace the vanity mirror bulbs. L322 TDV8 4.4 - current
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 146 ![]() ![]() ![]() |
Took her to the nearest ZF Service place and have them flushed the transmission, new filter and oil-pan, oil-change in transfer case, differential front and rear. |
Got the IIDBT tool.
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Well I had two choices after I done this too mine
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
New tailgate straps, ordered from Rob at Duckworth's on Friday, arrived yesterday, fitted today.
Bought mine the Dartford transmission flush service for the 4.2 |
