![]() | Home > In Car Electronics (L322) > £750 for a spare key.. would you? |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Just checked on the IID website and it states that some of the KVM modules on the 2010+ models are locked, seems that the IID tool can't add the new key if they are, however, you can send the module to Pat and he can program it. Maybe someone with SSD access could do the same thing if there is someone local to you 2011 TDV8 Vogue SE |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 ![]() ![]() |
Contact Boyd Beattie on Facebook his company pixels fixed are mobile and will be able to sort you out for a lot less |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2681 ![]() ![]() ![]() |
Sorry OP, Cheers Ian, I’m looking or a replacement Porsche key, he looks like just the man . |
I’ve used him a couple of times he’s brilliant and very helpful even over the phone |
Clobski Member Since: 21 May 2021 Location: Guildford Posts: 30 ![]() ![]() ![]() |
Great stuff thanks Ian.. think I need to give him a call.. fingers crossed I don’t need a new key module.. |
Ooo ok thanks.. you are kind of implying that the key module can be unlocked using software rather than the module being faulty as per LR position.. is that correct.. gives me hope.. ![]() 1966 Series 2A 2.25 Petrol SWB - Sold |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
What's he charge roughly for a spare key too be made. I've got the dodgy old BMW style key so it's well past its expiry date |
If the KVM is locked it is normally set to a specific number of keys in the address list. I suspect that it is possible to remove one of the existing keys in order to add another rather than unlock it as such. 2011 TDV8 Vogue SE |
👍🏻👍🏻 Thanks Denni .. 2010 RR 4.4tdV8 Autobiography
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 473 ![]() ![]() ![]() |
I used a chap in Huddersfield called P.D Auto Locksmith, probably no good for you due to location but he removed the KVM and re-flashed it with a new key, he also removed the old lost one from the system . Charged £200. There must be someone in your location who can do the same. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
As above - there are people that can do it.
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
You should be able to find some locksmith who can make a spare key for you. Not all have the means or knowledge to do it. I have the old BMW style and still had to enquire at several places before finding the one.
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 364 ![]() ![]() |
The KVM's can still be programmed, you just need a man in a van that has the right tools. I had a new key added and the missing keys removed on the drive for £200. Current
