Home > In Car Electronics (L322) > £750 for a spare key.. would you?
Clobski
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Baltic Blue
Thanks for the info VS322.. Andy if you are UK based who was it who did it for you? 2010 RR 4.4tdV8 Autobiography
1966 Series 2A 2.25 Petrol SWB - Sold
Post #605115 29th Aug 2021 1:30pm
woodrjh
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Buckingham Blue
Sussex auto locksmiths did mine with a home visit for £120. Found them on eBay, excellent service.
Post #607711 29th Sep 2021 6:04pm
woodrjh
I did just find an odd side effect of when my new key was programmed.
My car is set to required two presses on the unlock button to unlock all the doors and tailgate (I think this is easy entry disabled).
The original key worked fine, but the new key would not unlock the tailgate.
It would appear that the new key was in valet mode, but this was not enabled on the car.
To fix it, I unlocked the car with the new key, enabled then disabled valet mode, and now the key is working fine.
Strange...
Rick
Post #607880 1st Oct 2021 4:52pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
Rick,
"Easy Entry / Exit" is a menu option enabling the steering wheel to retract (reach) and lift (rake) automatically to facilitate driver entry and similarly when leaving the vehicle. Non-switchable on the early cars, disabling was a dealer operation, although I would assume owners of Gap IID tools would be able to do this.
Implementation varies with model year. With the electric steering column being a complex assembly and prone to failure over time, later cars (L322) sacrificed automatic retraction in favour of the driver's seat automatically sliding back and down. The wheel would still lift however.
Operation on later cars is dependent on current steering wheel / seat position settings being among those assigned to one of the three seat memory buttons. Eg. if you change seat position without saving, "Easy Entry / Exit" will stop working. Not sure if this applies to early cars mind - if it does, then could serve as a user workaround to disable the feature.
I think the option you're perhaps thinking of is "2 Stage Locking". First press unlocks the driver's door, second unlocks remaining doors including the tailgate. This is menu switchable although possibly only on later cars.
Keys/keyfobs for all iterations of the L322 had a separate button to "pop" the tailgate independently.
Hope some of this is useful.
Cheers, Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #607929 2nd Oct 2021 12:11pm
woodrjh
Ahem, yes, still getting used to the Range Rover settings and options.
I read the owners manual again and checked the settings and found the easy exit settings and the unlock settings.
All good now, thanks for the info.
Rick
Post #607934 2nd Oct 2021 1:39pm
