Home > Maintenance & Mods (L322) > Post 2010 L322 Rear Brake Overhaul
When you pull up in traffic and notice that smoke is pouring off the rear nearside wheel it's time for some work....! That's a problem with the S/C... 500+BHP and you just don't notice a sticking calliper....
Past experience tells me to just change the lot, so a trip to my favourite garage, a borrow of a lift, and the fun begins...
I decided to rebuild the callipers, new ones for the 2010 up L322 are £350 each, rebuilt, nearly £200 each....
The nearside was totally seized on but came off with just a little hammer work..! the offside looks like it had been partially seizing for some time... The offside calliper came apart fairly easily, an airline blew the piston out, no way was that happening to the nearside one, a club hammer and chisel was needed to get the piston out...
Nearside...
With both pistons out the bores looked fine
The pistons didn't look too bad either but apparently they can oval when they get very hot...
Everything else was stripped off and they were sent to the powder coaters to be finished in Dark Gunmetal, they were away for a couple of days and on return I rebuilt them with new seals and pistons along with a fitting kit.... Rebuilt and ready to fit with all new parts..
The new Brembo discs were already finished in what looks like powder coating... a very similar colour to the callipers.
The handbrake shoes are known to delaminate and jam the brakes up so it made good sense to replace them as well, they were fairly worn.
The back plates are also well known for rusting away so I wire brushed them and gave them a thin coat of Dinitrol ML to help them live a bit longer.. Fitted with new shoes and springs..
You can see where the offside calliper has been sticking in the past and allowing the disc to get like this...
Outside, all looks well...
Inside, rather poor.....
Then the fun bit begins, putting all the nice shiny bits back on....
Bedding in procedure.
What did it cost...
Calliper seals and pistons £30
Calliper and carrier sandblast and powdercoat £60
Brembo discs £102
Pajid pads £30
Pajid Handbrake shoes and fitting kit £38
So £260 in parts and about 6 hours over a couple of days... Less than the new price of one calliper...!!!
Should be sorted for a while now...
Edited for inclusion of bedding in procedure Pete
Post #599817 6th Jul 2021 5:00pm
Mike220
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Nice little write up, got this job to do myself in the next few weeks now all the bits have arrived 2011 Vogue SE Tdv8 FFRR
Post #599826 6th Jul 2021 5:40pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Very nice write up Thumbs Up
Post #599827 6th Jul 2021 5:45pm
Merchy
In the old vernacular 'Nice one cyril' Nice quality job and handy write up for folks. Shows how you can run a fatty without breaking the bank Thumbs Up
Post #599835 6th Jul 2021 6:20pm
Thanks guys, yes, I was shocked at the price of the callipers but the rebuild kit was cheap enough, as I wasn't in a massive rush I got it from https://www.autodoc.co.uk/
Much cheaper than others but, although a UK site, the parts came from Germany so took over a week to arrive.
I'm a southerner but have lived in Yorkshire since the last century so I like a bargain.... Thumbs Up Pete
Post #599894 7th Jul 2021 9:09am
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Nice - well done. I have used autodoc and their sister sites before for my autobox filter and fluid - really cheap compared to UK sites if you don't mind the wait.
Nice to know they are till working OK wit Brexit Thumbs Up
Cheers,
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #599895 7th Jul 2021 9:14am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Did you do the flexis too?
Post #599896 7th Jul 2021 9:16am
Thanks,
The flexis days are numbered but they have a few more years left in them... Thumbs Up Pete
Post #599904 7th Jul 2021 10:07am
Philip
That’s what I and the MOT man thought, just before one burst the other week…
Post #599910 7th Jul 2021 10:36am
It's not an exact science..... Laughing Pete
Post #599913 7th Jul 2021 10:42am
Merchy
I too have bought parts from Autodoc, all parts purchased so far were of very good quality.
If it's not an emergency, I don't mind the wait, simply plan ahead Thumbs Up
Post #599949 7th Jul 2021 3:29pm
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
I’ve done exactly the same job over the last 2 evenings! What was going to be a brake pad change turned out the same as you….discs, handbrake shoes….callipers weren’t as bad as yours but I’ll be probably changing them in the next 12 months…..
Post #600097 8th Jul 2021 9:20pm
Yes, the parts from Autodoc seemed good quality..
nambFFRR if you have the time, rebuild your own... saves a huge amount of money... Thumbs Up Pete
Post #600139 9th Jul 2021 10:00am
klj
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Great write up . SSL Engineering Wakefield do fully refurbed ones for 84 British pounds (e bay listing too). Finished in two pack colors . All oe . Got two the other day . ----------------
2010 RR tdv8 3.6 ( gone but not forgotten ...)
2012 RR tdv8 4.4
2004 RR 4.4 V8 (M62) -gone but not forgotten (sob)
1998 P38 RR - least said the better
2009 BMW 7 Series 3.0d
Various motor cycles - BMW GS
1998 Jag XKr 4.0 V8
Post #600182 9th Jul 2021 8:31pm
That's a good price, still twice as much as doing it yourself though and the powder coat will last much longer than paint... Thumbs Up Pete
Post #600187 9th Jul 2021 11:36pm
