![]() | Home > My Range Rover > 2k for 06 4.2sc |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 988 ![]() ![]() |
Well done that man, I did the same with my L322 the guy was selling as spares repairs with a report from his mechanic stating it needed head gaskets or a new engine. It didn't and I traced the fault to a leaky lpg water hose |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Well it wasn't meant too be. Took the range for a drive and after about 20 mins idle time and about 15 mins driving time, the temp started creeping up although there's still no movement from the fan so think first things first is to do the thermostat and change the clutch fan and see what the score with that is. Think I'll order a power probe first though so I can at least test the fan.
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Bluebottle & myself are still waiting for Saturdays Lotto Numbers |
Well the build it yourself thermostat turned up today however after a 14 hour shift at work I'll do it another evening. I've got the coolant ready so I'll get the stat changed and then refill it with water and see if the fan comes on this time. If it does then I'll get it bled up.
So early finish from work today so decided to do some investigation on the range for why it's over heating. I have a feeling this might be the likely culprit
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Someone's took out the thermostat because the viscous fan clutch has failed hopefully, you should be able to find a YouTube clip on the job, shroud will have to come off , might need special tool to access the holding nut opposite thread so tighten to loosen iyswim, maybe change out the water pump whilst your in there, idler pulley and belt as well |
B King.......Nice bikes |
Dingg1
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 606 ![]() ![]() ![]() |
stat failed on mine but ran cold on thermostat in car? |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
I agree with Mr Glover. Thermostat stuck open (or none at all) should result in 1/3rd temperature showing on gauge, not over heating?
I agree mate but considering the stat was missing I'm just going to overhaul the front end of it so then I know its done. Ordered new fan, water pump belts and radiator last night.
I can’t remember if you’ve already done this but have you also checked that the electric auxiliary pump for the charge cooler (to the right of the radiator behind the NSF headlight) is wired the correct way and is also working? There’s a LR bulletin somewhere on the forum as some were reverse wired at the factory?
His viscous fan is doing sfa, thats where my money is on being the only issue |
Well finally got home early one night so decided to make a start on the range. Still waiting for the fan to turn up. Bearmach decided they should send it from their warehouse to maltings warehouse instead of me so that's due today now🙄🙄🙄. Took everything I can apart and low and behold the fan shroud is destroyed. It would appear the previous keeper when removing the stat has broken the shroud but not replacing it properly as the fan was inside the shroud and left a nice little reminder of it for me. Time too order a new fan shroud. Still least I can take it all apart and get the belts changed as they are squealing away like my ex does when she don't get money 🤣🤣🤣
![]() On the other hand decided I'll treat myself too some of this. Pretty decent drink to finish the day on
