![]() | Home > Maintenance & Mods (L322) > L322 Rear arch repair |
kenneally_mark Member Since: 09 Jun 2021 Location: Cork Posts: 74 ![]() ![]() ![]() |
So while changing my discs & pads in the rear I thought I've to take off one arch liner so I might as well treat the arches to the preventative rust steps I've read about for the L322.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Nicely done, one comment about using hammerite. Hammerite is a great paint for sure, I used to work offshore in horrendous environments, we used to use hammerite which did a decent job protecting metal against salt water, we then discovered aquasteel, this is in a completely different league. It turns rust into an almost glass like surface, really hard and protected, easy to apply etc etc.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 856 ![]() ![]() ![]() |
I can also HIGHLY recommend Aquasteel - and we buy it in 25 litre drums - great for chassis refurbs as well |
Thanks for the tips with Aquasteel. I'll get some the next time I'm tackling an issue like that.
