Home > Technical (L322) > L322 2007 4.2 SC Timing Chain & Valve advice |
friskydog Member Since: 16 May 2018 Location: West Midlands Posts: 70 |
Hi all TECHIES...
1st Jul 2021 8:12pm |
Hi Kezbo... i have a misfire and a P0174 lean bank 2 error code. Reasons for these checks is also because I run LPG and wanted to be proactive if I saw any possibility of Valve Seat Recession. I had also just replaced rocker cover gasket so thought it was a good time to check whilst I had rocker off.
3rd Jul 2021 4:53am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8178 |
Does it throw the code on petrol and LPG or just one of them...
3rd Jul 2021 8:26am |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
Agree with Haylands re valve clearance and wouldn't necessarily jump to fix that to start with. Plus can you be sure of 0.06mm accuracy with a deeper gauge? If that is swarf near the timing chain that would be worth further investigation. |
3rd Jul 2021 8:38am |
I believe it throws the code on both Petrol and LPG. Buy I will double check that. Interesting about the Lambda sensors. I suppose misfire is all thats left but could that be the chain timing causing the misfire maybe. I have it booked in for a proper diagnostic but great nugget of info on Lambda Sensor, thank you for that 😀. Maybe redoing the tappets/reshimming is a no brained if chains have to be done, like you say with an engine that's done 115k already. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
3rd Jul 2021 9:10am |
Swarf that's a new word for me. I had to Google it lol.
3rd Jul 2021 9:14am |
Are you getting missfire codes...?
3rd Jul 2021 9:52am |
The bit I've circled in blue, is that where the chain is wearing against the block? Hard to see clearly. If it is, that's not normal and you would need to inspect the chains, guides and tensioners.
3rd Jul 2021 9:58am |
Yes, one mechanic had the code but didn't note it down. They say you can feel the engine misfire on cold start especially. Haven't had any misfire codes reappear recently however. But upon cold start engine does wobble a bit and settles when warm. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
3rd Jul 2021 10:07am |
I think the feeling of a misfire on a very cold start is quite common on the 4.2 SC engine, mine does it and always has since I have owned it. Ive researched it before and concluded its a common thing, known ab oiut with a possible software update fix . Mine runs perfectly after 30 seconds or so and so I have never bothered doing anything about it. Make sure you are chasing an actual problem! |
3rd Jul 2021 10:19am |
As Kezbo says they take some seconds to run clean...
3rd Jul 2021 10:31am |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 336 |
Kezbo: my MOT man describes this as a “7.5 cylinder V8” at start up and mine does the same as yours so I concur with you. |
3rd Jul 2021 10:32am |
Thanks for all replies I will book her in for full diags. Like you guys say and relay the outcomes. As they say u never own a Range Rover you have a relationship with them.
3rd Jul 2021 11:00am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 804 |
what Spark Plugs have you got in your 4.2 Supercharged ? are they Iridium and designed for LPG usage ?
3rd Jul 2021 11:09am |
