Home > Maintenance & Mods (L322) > replaced all bolts on the slam panel today
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
could be ott but replaced all the bolts with stainless steel bolts and washers see wear the alloy and steel come together and make the white powder they would rot and snap of then a hell of a job to drill out and tap . cleaned holes with gt 85 and put back with a lot of copper slip good job i am semi retired to much time on my hands but it is just nice to no that you have done your best
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #599163 29th Jun 2021 7:39pm
Not OTT... did mine last year...
Before
After
Did the air filter housings as well
And then the lower tailgate catches
Sure I'm sad enough to find some more as well... Thumbs Up
IMHO don't use copper slip with two different metals, you will encourage galvanic corrosion especially with some salty water in the winter, I use Dinitrol and have had good results in stopping further corrosion... Thumbs Up Pete
Post #599179 29th Jun 2021 8:43pm
oggy
haylands that looks so much better i see you used bolts wear the receivers go i have just got some dome ones coming because i thought it that it would fowl the bonnet when closing .done the 8 mm ones as well . looking good i am glad i am not the only one that likes it looking right i can understand ref the copper slip might slacken off tomorrow and do the same as yours yours new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #599185 29th Jun 2021 9:01pm
MTG2020
That looks good. I have bought stainless steel bolts to do mine as well. Very Happy
Post #599270 30th Jun 2021 6:51pm
Merchy
When I get time I will start doing the same.
Just one word of caution....... DO NOT drop any stainless fasteners down into the engine bay, as a magnet will NOT pick up stainless steel
Post #599293 30th Jun 2021 8:38pm
I used A2 Stainless which you can pick up with a strong enough magnet, you could use A4 Marine grade but not really needed on a fatty... Thumbs Up Pete
Post #599301 30th Jun 2021 10:13pm
Merchy
I stand corrected, once again Whistle it's all marine grade in my line of work. Just make sure it's not Chinese 'stainless' that rusts like hell.
Post #599313 1st Jul 2021 8:06am
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
I like the look of that, I'm going to have to do that myself me thinks. Nothing worse than opening bonnet to find rusty bolts everywhere.
Would it be safe to steam clean the engine? It's rather dusty and horrible, I'm rather anal about having dirty engines.
Post #599321 1st Jul 2021 9:17am
Mikey
And its better to use a ceramic grease, instead of copper Thumbs Up
Post #599323 1st Jul 2021 9:24am
Weegie
How would aluminium grease fare? John
GAP iiD BT
Post #599326 1st Jul 2021 9:39am
Use Dinitrol or some other anti rust treatment, IMHO better than most grease... Thumbs Up Pete
Post #599360 1st Jul 2021 5:33pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
And how much extra would it have cost Land Rover to do this from new, next to nothing. I really dont understand the LR mentality, a car that's designed to wade, go off road etc has fasteners that can corrode, sub frames that can corrode and brake lines that corrode. Absolute madness. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #599368 1st Jul 2021 7:35pm
p38arover
Australia
We don’t have that problem down here. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #599388 1st Jul 2021 10:59pm
p38arover
Australia
Double post Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #599390 1st Jul 2021 11:07pm
I suppose you get Dash crack and paint fade though..??
Why don't JLR do it better..?
Every design change and longevity upgrade have to pass the most important question car manufacturers ask....
"If we do that, will we sell more cars...?"
I guess you know the answer..... Laughing Pete
Post #599409 2nd Jul 2021 9:44am
