Home > Technical (L322) > TDV8 EGR replace
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
TDV8 EGR replace
Afternoon all I decided to replace my EGR due to being faulty Reduced Performance so I went and bit the bullet and so far it’s taken me 7hours Land Rover say that they can do it in 10hour it’s a right pig 🐷 of a job I wouldn’t attempt it again I haven’t finished it yet as I’m still waiting more parts and gaskets🤦🏽‍♂️🤦🏽‍♂️
I had got the part from Matlins in Doncaster very nice people to deal with 👍 and will let you all know how I get on
Post #598924 27th Jun 2021 4:14pm
kevinp
I'm watching with interest in the results.
Post #599107 29th Jun 2021 12:23pm
Simran0211
Further update I’m waiting for parts as the water outlet and thermostat housing are both cracked and as luck would have it caught it at the right time. And also rain has stopped play Big Cry
Rebuild unit ready to go on Thumbs Up
Post #599110 29th Jun 2021 12:33pm
kevinp
Could you see anything physically wrong with the old unit? Cheers Kev.
Post #599131 29th Jun 2021 4:54pm
Simran0211
No I can’t but what I have seen it could be the valve that’s electric on the side that maybe the culprit I’ll have a look tomorrow as I’m busy watching THE MATCH
Post #599136 29th Jun 2021 5:33pm
Simran0211
Also the DPF filter is saying that it’s full Censored
Post #599137 29th Jun 2021 5:48pm
Simran0211
Almost finished just need to change the oil then fire her up Bow down
Fingers crossed I don’t fancy doing that job again outside 🤣🤣
Post #599285 30th Jun 2021 9:05pm
kevinp
Fingers crossed for you mate.
Post #599296 30th Jun 2021 10:32pm
Simran0211
Well the oil arrive to day drained the old stuff and replaced fresh antifreeze started her up and it threw more codes at me but the old code for the whole job had gone only to be replaced by the following
Still have the reduced performance Big Cry and the wife is losing her cool and I’m loosing my hair Rolling with laughter if anyone has any ideas I’ll be only to greatfull Thumbs Up Thumbs Up
Post #599373 1st Jul 2021 9:35pm
GraemeS
Australia
The faults are referring to the sensor located in the left exhaust manifold. Was it disconnected and not reconnected? Its connector is in the vicinity of the rear of the left inlet manifold.
Post #599374 1st Jul 2021 9:47pm
Simran0211
Hi graemes is that looking from the front of the engine I had that off and out when doing the above work. I will check it tomorrow again. Many thanks it does it Bow down
Post #599375 1st Jul 2021 9:50pm
