![]() | Home > Technical (L322) > Trans Failsafe Prog P0705 |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
The OBD cover most certainly has nothing to do with all this imho.
From what I have read, the fsr failure manifests itself in the following fashion:
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 206 ![]() ![]() |
👍 I’d best check it out in that case. |
Best of luck! |
So, I forgot to mention that I also unplugged a Digital TV Tuner that didn't seem to work.
Looking good! |
So just to give an update, I've not had the issue appear again since unplugging the aftermarket Digital TV box in the rear.
Can you believe it, I got into the car just after adding my last update and it's done it again. |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Mines done the same in the past altho I've noticed it does it on my m62 v8 only if I get in the car quickly and turn it on quickly. Never actually caused me any issues so never worried about it |
I’ll have to check how fast or not I do and maybe leave it a few more seconds when I get in it tomorrow morning to go to work. 🤔 |
If you do narrow it down to the switch, then give it a good clean. If this can buy you some time until September, perhaps I could send you my switch by then. It works great but I have a brand new one I'd bought and ended up not needing and it'sabout time I put it in use...
vs322, that’s great thanks. I’ll see what I can find out and let you know 👍 |
Good 👍 |
