![]() | Home > Technical (L322) > Trans Failsafe Prog P0705 |
Could be a seized or seizing gear level selector rod, but this is usually evidenced by not being able to select a gear at all? Perhaps the nut has worked loose? You will need to get under the car and check the selector rod is well lubricated and correctly fitted and adjusted. .
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 205 ![]() ![]() |
Thanks, I'll check that out. |
By the way, there's never been any issue or stiffness when moving the gear lever, it's nice and free moving. It just seems to be when I start the car and select reverse to reverse out of my driveway, and it's just the first time on a given day, the rest of the day after it's absolutely fine. However I will still get under and grease it up just in case. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1001 ![]() ![]() |
Might be worth getting the inhibitor switch apart and giving it a clean
Thanks Phil, I did think that might be on the cards after looking at a load of posts on the forum.
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
Hi. I had the trans failsafe program warning pop up and the car would not start in P or, if it did, it would go into reverse with a thud and show the same message. I found an inhibitor switch at a reasonable price and imported it along with many other things prior Brexit. Turned out it was the battery though. I would first rule out the battery and then look into the inhibitor switch. Stealers here charge €1200 + VAT + labour. Got mine new for a third of that, so worth investing in one, especially if you can source it locally.
Thanks, I did consider it being the battery as I didn't know how long the old one had been on there for, so I just fitted a new one last week. it's done this twice now since |
Assuming you have checked the alternator output and used a proper battery, perhaps you should check the voltage in the morning having left the car parked overnight, in hopes it would be okay.
So just checking voltages quickly:
Seems like the alternator is doing its job and that you might be after some drain then...
I did notice before that when it went into Trans fail I lost the gear display on the dash and also rear camera stopped working. |
So it's a battery drain / low voltage problem, most likely |
Rear wiper works fine, will check headlamp wipers today. |
So this morning I started the car, just drove to work and no issues at all.
