Home > Maintenance & Mods (L322) > Any jack recommendations???
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I know most lads never get too hear this but it's better too have too much then too little
Think of trolley jacks and axle stands like a car engine
You wouldn't use an engine at it's maximum level every where you go, you use only 30% of it's ability so why would you make a jack and axle stand support the extra weight all the time
Post #598928 27th Jun 2021 6:44pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Ffrr-lover wrote:
So following the suggestions from people, I am favouring this jack and stands combo…
https://www.sgs-engineering.com/tj3x-jsr-3...xle-stands
3 tonne jack and 2 x 4 tonne ratchet axle stands.
I believe the 4 tonne stands are enough, (although there are heavier tonnage ones available) but do shout if you think 4T isn’t enough…
Hi All,
So an update for anyone who comes across this thread if looking for jack options…
I purchased the above jack and axle stand set from SGS, and while I cannot fault the quality of the jack or stands… they are not high reach enough for an L322. Jacking up at the usual jacking points doesn’t get the wheels completely off the ground and I’ve had to use wooden blocks to give me that extra reach - but even then I am near the upper limit of the jack.
My recommendation would be to stick with the SGS brand (I really cannot fault them otherwise) but check for the height they go.
At some point I’ll look to upgrade them to the higher reach, and 6T axle stand set. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #600994 18th Jul 2021 9:16am
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Jack options
There is another write up on the forum which covers the Mercedes Sprinter van bottle Jack. It also covers the use of a machined alloy part made to fit the jacking points of the L322. I bought these and recommend them. My drive is not exactly fat and a trolley Jack works but will move around! Many people here have gone this route.
Post #601030 18th Jul 2021 12:58pm
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Went for yin oh these with the Halfords Trade Card, currently £128.
https://www.halfords.com/tools/garage-work...57321.html
It's very good and worth what I paid which I think was about £110, some 18 months ago.
Post #613993 28th Nov 2021 1:04am
Range Rover L322
There are lots of 6 tonne axle stands on Facebook marketplace and ebay
Post #614016 28th Nov 2021 3:10pm
bogdan xtr
Romania 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Try mercedes sprinter double piston bottle jack.
Post #614206 29th Nov 2021 10:31pm
