Home > Technical (L322) > Park Brake Fault - Safe To Drive?
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
My '11 TDV8 came up with the 'Park Brake Fault' this afternoon.
IID suggests "U2002-92 (2B) Switch general electrical failure - Component failure - performance or incorrect operation".
The park brake goes on fine and I only see this when I try to turn it off. Any ideas?
If I force the car to move it shows some resistance but then feels free when I try to roll it down a gentle slope.
Am I safe to continue to drive the car?
Post #598611 24th Jun 2021 6:47pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
One of my caliper motors failed the other month & would not disengage the handbrake, if its running free with no heat build up, you’ll be fine to drive it , but get it looked at sooner rather than later . Mine started the same as yours then eventually jammed on making it undriveable.
Post #598613 24th Jun 2021 7:39pm
