Home > Maintenance & Mods (L322) > Is this normal for the front upper control arms
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Just looked under the car and noticed a gap in the control arm bush, it’s exactly the same on both sides I took a video (no idea how to upload a video) does this look normal
 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #598509 23rd Jun 2021 7:23pm
Merchy
In my experience the following would apply. - Bush - gap - toast - buy new one(s) Thumbs Up
Post #598513 23rd Jun 2021 7:44pm
kevinp
I would say they look completely worn out. Mine look the same but passed the MOT 2 months ago!! Was expecting it to fail.
Post #598530 23rd Jun 2021 9:19pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
How does the front end feel when driving?
Post #598533 23rd Jun 2021 9:37pm
Merchy
I would expect some knocking, even if slight, and difficult to hear.
As for your comment Kevinp, I think you have found the 'Holy Grail'.... A blind Range Rover MOT tester Rolling with laughter Everyone on here will want the name of your MOT test station. Thumbs Up Where I go they seem to have X-ray vision Big Cry
Post #598534 23rd Jun 2021 9:56pm
kevinp
I agree Merchy. It was a main dealer as well!! I get quite a loud bang/thump when braking sharply and I'm sure it's them bushes.
Post #598537 24th Jun 2021 12:00am
Furnitureman
No issues when driving but noticed a thump on entering a car park that has a speed bump you hit at an angle, the video I too shows the arm moving in and out on the bushing going to take it to my indi for a quote, 2012 Range Rover Westminster 4.4 TDV8
Post #598538 24th Jun 2021 5:07am
kevinp
I think the bush number is LR018345. Have a look at a picture of one. They are hollow but yours do look torn as do mine. Let us know how you get on. Cheers Kev.
Post #598546 24th Jun 2021 7:26am
GraemeS
Mine need replacing every 12 months as the bush doesn't stand up to rough roads.
Post #598559 24th Jun 2021 8:54am
kevinp
Do you replace the whole arm or just the bush? I've got a 20 ton shop press and was thinking of replacing the bushes. you must have some rough roads out there mate for the bushes only to last that long.
Post #598566 24th Jun 2021 9:28am
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
The bush doesn't stand up to The Bush? Rolling with laughter
Post #598567 24th Jun 2021 9:44am
GraemeS
I replace the bushes using a 10T press.
Pot-holes and bumps on unsealed roads at speed knock the bushes about quite a lot. It's the variable traction of the wheels while pulling forwards on rough surfaces that does the damage. Prior to fitting the most recent pair I filled the rear void with marine polyurethane but found that 2 weeks wasn't enough time for the polyurethane to cure inside so a lot leaked out when refitting the arms so next time I'll fill in layers. I tried poly bushes only for a very short time as I didn't like the harshness they caused.
Post #598570 24th Jun 2021 9:55am
kevinp
Good idea though. I guess poly bushes are for track day cars.
Post #598575 24th Jun 2021 10:09am
Furnitureman
It’s going in tomorrow for both to be sorted just awaiting the quote any ideas on cost using genuine or aftermarket 2012 Range Rover Westminster 4.4 TDV8
Post #598594 24th Jun 2021 2:00pm
GraemeS
I use the Lemforder bushes which I understand are the OEM supplier.
Earlier this year Meyle, who produce a standard duty version of this bush, said that they would look into producing a HD version but I don't know if they've made any progress. Meyle produce a HD version of the equivalent bush on a D4 which people report as not making the ride any different to the LR hydro bushes yet last longer with outback travel use.
Post #598636 24th Jun 2021 9:11pm
