![]() | Home > Maintenance & Mods (L322) > Is this normal for the front upper control arms |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1223 ![]() ![]() ![]() |
In my experience the following would apply. - Bush - gap - toast - buy new one(s) |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1278 ![]() ![]() ![]() |
I would say they look completely worn out. Mine look the same but passed the MOT 2 months ago!! Was expecting it to fail. |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
How does the front end feel when driving? |
I would expect some knocking, even if slight, and difficult to hear.
I agree Merchy. It was a main dealer as well!! I get quite a loud bang/thump when braking sharply and I'm sure it's them bushes. |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 351 ![]() ![]() ![]() |
No issues when driving but noticed a thump on entering a car park that has a speed bump you hit at an angle, the video I too shows the arm moving in and out on the bushing going to take it to my indi for a quote, 2012 Range Rover Westminster 4.4 TDV8
I think the bush number is LR018345. Have a look at a picture of one. They are hollow but yours do look torn as do mine. Let us know how you get on. Cheers Kev. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Mine need replacing every 12 months as the bush doesn't stand up to rough roads. |
Do you replace the whole arm or just the bush? I've got a 20 ton shop press and was thinking of replacing the bushes. you must have some rough roads out there mate for the bushes only to last that long. |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 ![]() ![]() ![]() |
The bush doesn't stand up to The Bush? ![]() |
I replace the bushes using a 10T press.
Good idea though. I guess poly bushes are for track day cars. |
It’s going in tomorrow for both to be sorted just awaiting the quote any ideas on cost using genuine or aftermarket 2012 Range Rover Westminster 4.4 TDV8
I use the Lemforder bushes which I understand are the OEM supplier.
