Home > Maintenance & Mods (L322) > More battery drain woes!
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
My ff has ongoing battery drain issues. After replacing battery and alternator a parasitic draw was traced back to fuse 49.
It was initially thought that removing the fuse gave a draw of 0.02 but a further check yesterday, with the fuse removed revealed a FLUCTUATING draw of between 0.02 and 0.04.
Electrician has checked all the infotainment modules in the boot and all seem to be ok.
Has anybody experienced this?
Any ideas as to where to go now with this nightmare?
Post #598446 23rd Jun 2021 10:24am
What is the draw with fuse 49 in ? 0.02 - 0.04 amps seems acceptable with it out.
You may need to inspect the internals of the infotainment modules, as in my search everything was "working" but one of them was causing a drain. .
Post #598449 23rd Jun 2021 11:19am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
I know it's for the D3 but it might help give you an idea.
here
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #598451 23rd Jun 2021 12:01pm
kgeddes
Thanks Joe and Ivan.
Battery drain is amps. With fuse 49 in, draw is 0.05.
If I fully charge the battery to 12.7v, with general very short journey use, in about two weeks the battery will read around 12.0v.
Post #598479 23rd Jun 2021 3:42pm
Sounds about right......lots of electrical energy used on short trips, not enough time to charge up. .
Post #598485 23rd Jun 2021 4:23pm
Embarassed
Post #598491 23rd Jun 2021 4:45pm
kgeddes
Thanks again Joe.
I fitted a Varta 020 battery today and noticed the negative battery terminal clamp was very loose on the ‘old’ battery - tightened up on Varta. Hopefully this may help a bit.
Post #598506 23rd Jun 2021 6:55pm
V8Simon
United Kingdom 2004 Range Rover Vogue SE Td6 Java Black
My drain was the offside front headlamp wiper motor. Pulled that fuse and its been fine for 12 months now where is slowly killed a new battery over the summer last year. 2004 Vogue SE TD6
(Also a LR 90 V8 & RRS, just because)
Post #599003 28th Jun 2021 2:31pm
kgeddes
Thank you V8Simon.
Since fitting the Varta 020 battery readings over last six days have been between 12.5v and 12.7v so looking good, at the moment…… Thumbs Up
Post #599016 28th Jun 2021 4:29pm
