Home > Technical (L322) > Transfer Box Motor Fault? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 965 |
The ‘Fuse 37 trick’ was for earlier L322s with the NV225 transfer case, where you could force the transfer box shift motor to select neutral (primarily for towing the car on all four wheels for recovery purposes). This doesn’t apply to the later DD295 Magna Steyr transfer box because short distance (30 miles) and low speed (<30mph) recovery towing is permitted in high range.
19th Jun 2021 3:36pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3086 |
Thanks Phil,
19th Jun 2021 5:05pm |
Although I can see why the warnings would come up if the spline was slipping, due to the mismatch in speeds, I agree that (after clearing) they wouldn’t be displayed if you just turn on the ignition, before you’ve even started the engine and selected Drive or Reverse. Hopefully, then, it is just an electrical gremlin.
19th Jun 2021 5:43pm |
Thanks Phil,
19th Jun 2021 5:51pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
It sounds as though the transfer case isn't engaging properly and that when driving forwards the gears are holding engaged enough to provide drive but when spinning backwards the gears disengage enough to jump teeth.
19th Jun 2021 9:11pm |
Unfortunately due to the electrical fault codes that are stored I can’t do anything. As soon as I turn the ignition on the Lo light on the dashboard flashes and the Hi and Lo lights on the switch both flash so I can’t do anything to change the range.
19th Jun 2021 9:25pm |
I’ve just found this online which suggests I won’t see a resistance change across the sensor if it’s a HALL sensor.
19th Jun 2021 10:56pm |
The transfer case numbers have changed over the years but they supersede to the latest number.
19th Jun 2021 11:28pm |
Another interesting point is that when the car lost drive it was in Lo range.
19th Jun 2021 11:47pm |
I've been giving everything another check over this afternoon.
20th Jun 2021 1:58pm |
I went to see a friend this afternoon who has a TDV8. I plugged my ECU into his car and tried to clear the fault codes. Despite clearing them, the same 5 codes in the Terrain Response ECU came straight back, as did the one in the TCCM and the one in the Vehicle Dynamic ECU.
20th Jun 2021 4:54pm |
Has the solenoid been removed? If so then it must be energized during refitment according to the D4 WSM. |
20th Jun 2021 9:41pm |
No, thankfully the resistance was a doddle to measure with it in situ. I was doing my best to avoid removing it as I’d read that online about refitting.
20th Jun 2021 11:46pm |
A different control module will have to be calibrated.
21st Jun 2021 8:51am |
