![]() | Home > Technical (L322) > L322 suspension |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Welcome along mate
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Not sure if the Snapon set will do the job but as mentioned above a GAP iID Bluetooth unit the unit most will recommend and does it all, coding, fault code reader and clearer plus setting ride height etc |
Also the air suspension is easy enough to work on and no special tools other than a ride height setting / fault clearing tool like the GAP iID.
Craig62 Member Since: 20 Jun 2021 Location: Perthshire Posts: 3 ![]() ![]() |
Cheers guys. Is there a reason why I can't open the rave manuals on the wiki section? |
Fat fingers?
Think you need to have a made a few posts to see it. Sure stan will be able to verify |
Update. Took it to local independent guy who has very good reputation. Front n/s air bag has a hole. His advice was probably best to change complete strut as the plate that the air bag sits on may well be rusted. Emailed Duckworth for a price. |
