Home > Technical (L322) > L322 suspension
Craig62
L322 suspension
Hi all, new to this forum but not to the green oval. Had a P38, Defender County Station Wagon in the past. Got a Defender Commercial for work now. Also, in a moment of weakness, bought a 56 plate Td6 L322 in December last year. Its already bit my wallet to the tune of £3k, torque converter and recon gearbox! Today, the air suspension dropped the bump stops!!
Compressor was hot as there's a leak on n/s front air bag.
Questions:
Will Snap-on Ethos read/clear codes?
Is changing air bags easy enough for a half decent spanner twirler?
Where can I get a decent workshop manual from?
Sorry for long post on Sunday morning. TIA for any help/answers.
Post #598123 20th Jun 2021 10:10am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Welcome along mate
Everyone rates gap iid tool on here but should get the basic stuff done with snap on
Changing them is nice and easy, get some new bolts though as yours will be rusted to hell so easier to grind the nut of and pop the bolt through
Look on the Web page version of this site and you'll find the manuals under the wiki section
Post #598127 20th Jun 2021 10:18am
ur20v
A Trap
Not sure if the Snapon set will do the job but as mentioned above a GAP iID Bluetooth unit the unit most will recommend and does it all, coding, fault code reader and clearer plus setting ride height etc
Post #598138 20th Jun 2021 11:31am
ur20v
A Trap
Also the air suspension is easy enough to work on and no special tools other than a ride height setting / fault clearing tool like the GAP iID.
If you have had a leak, you may want to consider a new air suspension pump or rebuild kit.
**Just be aware you need to depressurised the air suspension system after the car has been raise on axle stands on all four corns and before removing hoses… the car will collapse to its bump stops and the air hoses can whip out and cause injury or damage.
Post #598139 20th Jun 2021 11:43am
Craig62
Cheers guys. Is there a reason why I can't open the rave manuals on the wiki section?
Post #598152 20th Jun 2021 2:04pm
ur20v
A Trap
Fat fingers?
Otherwise, I don’t know 😇
Post #598165 20th Jun 2021 5:00pm
Bean19844
Think you need to have a made a few posts to see it. Sure stan will be able to verify
Post #598168 20th Jun 2021 5:28pm
Craig62
Update. Took it to local independent guy who has very good reputation. Front n/s air bag has a hole. His advice was probably best to change complete strut as the plate that the air bag sits on may well be rusted. Emailed Duckworth for a price.
Post #598250 21st Jun 2021 12:21pm
