Home > Technical (L322) > 2006 Vogue Reverse issue |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
The system does indeed stay live for a short while after driving off sir... |
19th Jun 2021 1:14am |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 |
Morning, if there is an issue with the reverse light switch it is a separate issue from the sensors giving a constant tone. When selecting reverse, apart from the obvious, it will merely make the PDC system live. If there is nothing withing range of the sensors you won't hear anything. If there's a problem with the reverse switch not operating when engaging reverse it simply won't activate the PDC system.
19th Jun 2021 9:18am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Agree as in above posts, sounds like you have two problems, intermittent reversing switch fault as you say sometimes the reversing lamps do not come on, and a fault on the sensors. |
19th Jun 2021 11:50am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Believe it or not corrosion on the surface of the sensor will cause a problem similar to what you are experiencing. I had similar and simply emery papered the surface of the sensors and repainted them. Problem solved and not returned for a good few years. |
19th Jun 2021 11:56am |
allandwf Member Since: 11 Nov 2018 Location: Forfar Posts: 16 |
Thanks all. I will start by checking the sensors as previously described on here. Then take it one thing at a time. |
19th Jun 2021 6:20pm |
