Home > Maintenance & Mods (L322) > Fault Code: P023D-22 (2F) - Any idea's
kenneally_mark
Ireland 2012 Range Rover Westminster 4.4 V8 Santorini Black
Hi!
I've got the fault code:
P023D-22 (2F) Manifold absolute pressure - turbocharger/ supercharger boost sensor A correlation - General signal failure - signal amplityde>maximum
Any idea's what could be causing it?
Thanks!
Post #597596 15th Jun 2021 2:19pm
That basically means the pressure measured by the MAP (Near air box) is providing a different reading to Sensor A whish is inside the air intake. (IIRC)
Burst hose or other inlet leak or hole or a faulty MAP or sensor A...
Live values may help to narrow it down... Thumbs Up Pete
Post #597599 15th Jun 2021 2:27pm
kenneally_mark
Thanks for the detailed reply!
I just got my IID tool yesterday. How do I conduct live values readings?
Sorry I'm new to using the tool and also RR ownership!
Thanks
Post #597601 15th Jun 2021 2:29pm
kenneally_mark
Mani absolute pressure 1 : 100.0 kPa
Mass Air Flow 1: 44280.0g/hr
Mani absolute pressure 1 : 102.0 kPa
Mass Air Flow 1: 32400.0g/hr
Are these the readings required?
Thanks
Post #597607 15th Jun 2021 2:54pm
DrRob
Best way to diagnose a potential hole/crack/split in the system is with a HIGH pressure smoke test.
Not all places to do it. Lots do a LOW pressure one but that's not good enough to diagnose.
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #597612 15th Jun 2021 3:18pm
kenneally_mark
Cool! Thanks for the advice, any idea on a brand or make so I can buy one?
Post #597628 15th Jun 2021 5:19pm
Jazzy
Take the top two hoses off and have a look.
I had the same fault along with black smoke on boost, and a lack of power.
Sure enough, split hose on RHS underneath.
It’s a couple of worm clamps, 5 mins at best.
https://www.advancedfactors.co.uk/intercooler--hoses-1949-c.asp
https://www.lrdirect.com/PNH500510-supplie...ROVER.html
https://www.lrdirect.com/PNH500500-supplie...ROVER.html
I’ve ordered this:
https://www.lrdirect.com/DA4781-supplied-b...TPART.html
Which according to LRdirect is ‘silicon hoses’, according to britpart themselves is coolant hoses
https://www.britpart.com/parts/performance...ses/da4781
And according to island4x4 is actually intercooler hoses, so we’ll see what turns up Smile
https://www.island-4x4.co.uk/hose-intercoo...37387.html
Post #597641 15th Jun 2021 7:57pm
There are a few home made smoke machines using a cigar on youtube... Hope that helps sir Thumbs Up
Post #597659 16th Jun 2021 12:41am
kenneally_mark
Thanks for all the replies! I've ordered 4 new hoses from my local LR garage. They should be here by Friday so I'll keep you guys posted. I'm also bidding on a leak detector machine to have even if the issue is fixed as all four cars are Turbo cars.
I'll put up the results on how it goes. Thanks
Post #597693 16th Jun 2021 11:16am
Jazzy
I’ve ordered this:
I can confirm they are intercooler hoses, took me 15mins end to end
Post #597719 16th Jun 2021 5:40pm
kenneally_mark
So thanks to everybody who replied on this topic, I appreciate it.
The update is:
I ordered the four smaller hoses from my local LR dealership.
When I stripped things down I found that it was one of the larger ones from the front, instantly called the LR dealership and ordered those. I gathered them on Monday morning and fitted all six hoses. Put the lot back together, cleared the faults with the IID tool and test drove it.
It's going well and much smoother. I'm happy I've changed all of the hoses as I don't fancy that stripping again.
Post #598444 23rd Jun 2021 10:34am
