![]() | Home > Technical (L322) > electrics not shutting down |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
Well, bizarrely it seems to have resolved itself - which I can't explain
I'm also not having the weird "static" thing on the satnav screen when starting the car, switching to the Naviplus seems more reliable too. Very weird, not aware of having done anything to the car to change the behaviour. Only thing that's changed is the weather's got a bit warmer, from ~13 degrees overnight to >20, which I wouldn't think is enough to affect it but who knows ![]() |
RosieL322 Member Since: 20 May 2021 Location: County Durham Posts: 26 ![]() ![]() ![]() |
I have been investigating a similar problem on my 2006 TDV8. Initially it wasn’t going to sleep at all but I know the old Bluetooth module was defective, so unplugged it and looped the MOST out with a kit from eBay. So far the system goes to sleep now after 16 minutes. Losing about 0.02v a day from the battery so should last a week at least now. Seeing some difference between road height and access height when parked though. I know the system checks the vehicle height every few hours and tops up if needed. That may be your spike and could be a slight air leak somewhere. That’s the theory I’m checking anyway |
I think that's probably a red herring to be honest. From what I've seen in the workshop manual the suspension is checked every 6 hours.
You are most likely right then. I thought it topped up too, not just let down to balance. Do all the ECU’s all wake up again or just the ride height? |
When a door's opened, keyfob used to unlock etc the BCU wakes up a bunch of stuff, boots the satnav, starts checking the temperature, wakes the suspension ECU etc.
I read elsewhere that the Bluetooth module can be activated by other signals when in sleep mode which can wake it up. I have mine unplugged and don’t have a battery drain anymore so is that worth a try? |
I don't know technically why it'd be necessary for a Bluetooth module to wake-up the BCU - but it also would not surprise me if it did |
That looks perfect, thank you. Is that how you got the logs in the thread above? If it could send me a message once the battery drops below a value, that would be really useful |
It is indeed, yeah, it can be set to give you a push notification when the battery falls below a certain threshold.
I will get one ordered and see what’s really going on |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
Most of my dash is off, have decided to fix/replace damper motors whilst chasing the drain. With the Audio system offline there is no drain over night!! shock: next step would be to isolate carplay and check further. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
This may just jinx it but no more battery drain issues since isolating the Bluetooth unit. 🤞 |
Interesting update! Would be curious how you get on! ![]() |
Crossing my fingers for you too! ![]() |
