![]() | Home > Technical (L322) > electrics not shutting down |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
None of the forum posts I've seen have said definitively whether you can have a fully functioning blower (ie: all the speeds appear to work, it responds normally to the controls) and it still be faulty.
After a long drive yesterday (starting with a fully charged battery) I left the car overnight with the battery monitor logging the state of charge.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1301 ![]() ![]() ![]() |
See if you can find any info on the suspension system checking itself for being level when the car has gone to sleep. I know I've read it somewhere. |
Yes, it could definitely be that - I've seen it quoted as happening 1 hour and 24 hours after shutdown, which doesn't exactly coincide with this but it's a possible.
Todays update in our ongoing battery saga...
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
where is fuse 62 ? i only have fuses go up to 60 in glove box !! |
Could be model year differences, mine's a MY2011 and this is the fusebox and the associated listing for it.
hiya, where is this fusebox located!! under the bonnet, boot, , i think my layout is different
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3260 ![]() ![]() ![]() |
Bob, On your Model Year Air Conditioning shows as fuse 12 in the fuse box behind the glove box. Try that to see if you get a result.
The one pictured above is the fusebox behind the glove box, on a MY2011 TDV8 4.4. There's also a bunch of fuses just in front of the battery under the bonnet (on a LHD vehicle, I guess on a RHD vehicle it's also in front of the battery even though the battery is on the other side?) Lastly, there's a fuse box in the right hand side rear of the boot. Which has some more fuses, including some relays and some larger 40amp fuses. Again, all this on a MY2011 4.4 TDV8, others maybe a little different ![]() |
Updates on the above saga...
hi john, ive tried 12 and 34, but does nothing !! trying to try 62 but cant find , glovebox only up to 60 !! bob hope your keeping well |
In the front fuse box they only go up to 60 on yours. They then start at 71 on the rear fusebox. No 62. John
hi john,
