Home > Technical (L322) > Air suspension Inactive |
chinkoa Member Since: 17 Jan 2014 Location: West Yorkshire Posts: 34 |
I have replaced the front offside air bag and strut, Front offside Height sensor, rear offside Height sensor. Reset all height parameters without any issue. Then I get "Air Suspension Inactive" I can clear it and it remains cleared sometimes for 1/2 an hour. Now I can clear it and it can come on again within minutes and without the car moving. When it stays on the height can be controlled IE up to its high setting and down to its low setting. Compressor pressure and temerature all seem to work as you would expect. Pressure settles at 188psi. Car height never varies at any time in use or not.
10th Jun 2021 9:02pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1158 |
https://fusesdiagram.com/range-rover/fuses...-2012.html
10th Jun 2021 11:05pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8066 |
Second that, take it for a drive, full lock to lock and take it from there...
10th Jun 2021 11:13pm |
Hi Martin,
10th Jun 2021 11:15pm |
Merchy and Haylands,
12th Jun 2021 7:34am |
You can replace the exhaust valve or just drill a hole though it, basically it's a filter for the exhaust...!!
12th Jun 2021 10:25am |
Hi Pete,
13th Jun 2021 11:54am |
At the moment the only other thing I can think of trying before any more diagnosis would be to start the car on level ground after clearing the fault, then repeatedly go from access / road / off road heights, keep going up and down numerous times,over and over a quick easy check. Just do it when the neighbours are not watching.
13th Jun 2021 12:47pm |
I had an engine fault, fault, on my early one, it came up with an engine fault now and again and there was nothing wrong so there is a precedent for it....
13th Jun 2021 9:05pm |
I stand corrected, Haylands you definitely know your onions Sir Thank you for the info, as I regularly read your posts, I may be an engineer, but am still a relative novice when it comes to FFRR's |
13th Jun 2021 9:14pm |
