Home > In Car Electronics (L322) > 2008 Audio/head unit fault |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Just to clarify, I ran the IID tool scanner over the car when the intermittent audio problem appeared. The IDD showed the same fault. The below fault is from two weeks ago.
13th Jun 2021 1:50am |
Also, I did review the below wiki post.
13th Jun 2021 6:54am |
bikeman Member Since: 10 Dec 2018 Location: Sydney Posts: 21 |
Hi, I had a similar problem a while ago. It turned out to be moisture getting into to LH rear compartment where all the phone, tv, DVD stuff is. I replaced the phone module, which was the culprit and all was good. Apparently if moisture gets into any of the modules it can affect all of them as they are connected via a fibre optic cable, which hates water. Water can enter this compartment via a blocked rear sunroof drain. I hope this helps.
13th Jun 2021 7:51am |
thanks, I'm assuming Brisbane humidity has finally had an impact. Even though its winter here in SH.
13th Jun 2021 10:27am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Bypass the Nokia unit to establish if it is that before buying a new one. John
13th Jun 2021 12:32pm |
Thanks. Good idea. ______________________________
13th Jun 2021 7:58pm |
Today I finally got around to by-passing the Nokia unit. But no change. Any other suggestions? Thanks.
13th Jul 2021 4:33am |
ash27 Member Since: 23 Jun 2020 Location: Hertfordshire Posts: 46 |
Did you wrap that at all? I did the same in mine but wrapped it all with black electrical tape.
14th Aug 2021 2:35pm |
Thanks Ash. Finally got back to this. Wrapped it all up in black tape. But no luck unfortunately. ______________________________
28th Aug 2021 1:25pm |
All resolved. It turns out the problem module was a Mobridge digital radio receiver I added. Currently by-passed. Will disconnect power and remove eventually. ______________________________
10th Dec 2021 12:52am |
