Home > Maintenance & Mods (L322) > Rear door wheel arch seals broken?
garyRR
I had a search of the site but couldn't find anything specific on the rear door seals - most articles were about sealing the wheel arches.
Both my rear door seals are loose. Looking at the door and the rubber, there is a little hole in each, which I presume had a little plastic rivet in at some point? And, the seals don't actually hold in place by being inserted into a channel?
Anyway, there's nothing wrong with my seals, except they've come loose. I was expecting to search eBay and several aftermarket options come up but, there was nothing.
Is this a common issue (I'm assuming yes)? Is there a way to just re-attach the existing seals? Are there replacements available and if so, where from? Can they just be bodged and reattached with Sikaflex?
 2015 Range Rover Autobiography 4.4 SDV8
Post #597229 12th Jun 2021 8:53am
There is a full length plastic strip with the clips moulded into it, they aren't a lot of money from the dealers but yeah, Sikaflex or 3M VHB tape would do it... Thumbs Up Pete
Post #597231 12th Jun 2021 9:18am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Looks like the thin plastic strip is still there in the photo - should have fixings on the reverse side that clip into the holes.
Post #597232 12th Jun 2021 9:23am
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Exact same problem - my clips no longer ‘clip’ at the lower end. I was planning to bodge it with an impact adhesive. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #597237 12th Jun 2021 10:14am
Merchy
As Haylands say, you can use various adhesive tapes, looks like the fastening strip bits may have broken off / perished. Below link is for the fixing strip you MAY need to refit. Different part for left and right doors.
https://www.johncraddockltd.co.uk/lr031396...al-lh.html
Mind you, if it was just the lower bit loose, adhesive tape will be a good answer and cheap, my favourite type of repair Thumbs Up
Post #597238 12th Jun 2021 10:25am
GraemeS
I recently purchased an assortment of plastic clips hoping to fit individual clips when I get to clean-off all the mud.
Post #597262 12th Jun 2021 8:53pm
GraemeS
I fixed mine by cutting off the plastic clip strip just clear of the bottom hole then used a fir tree clip to hold the trimmed end of the strip. There's now no plastic strip past the bottom hole but it never held the seal in place anyway.
Post #597401 14th Jun 2021 2:55am
garyRR
Sorted!
I had some clear sanitary silicone left over from a bathroom job so, put a big blob at each hole where the plastic strip would normally secure, plus a thin bead along the length.
I then held it in place with gaffa tape along the length plus, round the door edge then, shut some rags in the door to ensure the seal pressed sufficiently along the silicone and then just left it overnight. 2015 Range Rover Autobiography 4.4 SDV8
Post #598836 26th Jun 2021 9:26am
TDV8 Paul
I had this, I got a load of fir tree fixings and trimmed them to size- worked perfectly 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #598918 27th Jun 2021 12:54pm
