Home > Technical (L322) > Parking brake error |
Tattiepicker Member Since: 01 Apr 2021 Location: Aberdeen Posts: 51 |
I also had some error codes that might have be connected and causing an issue. Possibly a wheel speed sensor and height sensor? I’m having a look Into the wiring diagrams and will check all the fuses to rule out the obvious. Is there a way to check the wheel sensors and suspension on the iid tool? |
10th Jun 2021 7:06pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8164 |
Maybe it's the internal temp sensor that has failed...!! Pete
10th Jun 2021 10:19pm |
That could be a possibility. Would that allow me to remove the park brake as usual but not apply it? Seems a strange fault to me that resets and doesn’t come back in until you try to apply the brake. I could be overthinking and it’s something that simple |
11th Jun 2021 6:23pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3760 |
I have read on here somewhere about the harness wiring being very stressed tight and chafing, but sorry I have been trying to search the post but can’t find it.
11th Jun 2021 6:54pm |
